Author Topic: Self ballasted mercury vapor in busted HPS light  (Read 2313 times)
mefurd98
Self ballasted mercury vapor in busted HPS light « on: October 30, 2018, 08:13:35 PM » Author: mefurd98
I have an HPS yard light that has a bad ballast in it. I was wondering if a self-ballasted MV bulb would work in it or would it destroy the bulb????
Re: Self ballasted mercury vapor in busted HPS light « Reply #1 on: October 30, 2018, 09:01:49 PM » Author: sol
Your safest bet would be to bypass the ballast and ignitor first so the lamp holder gets your normal mains voltage.
I'm not sure if SBMV lamps have a starting resistor or not (but I believe they do) so a hot restrike would obliterate it when the ignitor tries to strike the lamp. HPS is always pulse start.
Re: Self ballasted mercury vapor in busted HPS light « Reply #2 on: October 30, 2018, 10:32:25 PM » Author: dor123
120V SBMV lamps, don't have starting resistors like the 230V SBMV lamps and regular MV lamps, but have preheating filaments instead, and a bi-metal that disconnects them several seconds after the lamp is lit. The restrike period of the lamp, is determined by this bi-metal, in which time it will take to return to preheating mode (Aka. closed).
mefurd98
Re: Self ballasted mercury vapor in busted HPS light « Reply #3 on: October 31, 2018, 03:26:32 PM » Author: mefurd98
Thanks! I've been wondering about that for a while. I just didn't want to kill one of my SBMV bulbs testing it out.  :)
Re: Self ballasted mercury vapor in busted HPS light « Reply #4 on: October 31, 2018, 04:41:33 PM » Author: sol
I’d still bypass the ballast just in case.
