Author Topic: Restrike standby relay module  (Read 2948 times)
Restrike standby relay module « on: October 15, 2018, 03:56:40 PM » Author: sol
I use a MH ballast box cobbled together with some kind of refractor (changes every so often when I decide so) to light my shed. It is the only source of light there, and the other sources nearby are all HID. So I'm thinking of adding a standby lamp with a special restrike relay. I have a couple of questions, thought.
This is all 120V, magnetic gear, HX-HPF, 50W.
1. Since the restrike relay is not connected to a different tap on the ballast, it is connected together with the 120V supply, can I use a standby lamp of greater wattage than the MH ? (let's say a 100W stand by lamp)
2. Does the stand by lamp need to be a quartz lamp normally sold for that purpose ? Can I use a standard incandescent lamp ? I plan on remote mounting the stand by lamp in it's own fixture, only about 1-2 feet from the ballast housing.
Many thanks.
Re: Restrike standby relay module « Reply #1 on: October 21, 2018, 01:02:13 AM » Author: Medved
Yes to both questions...
But make sure you do not overload the relay switching element (whether that is a triac and/or contacts).
Re: Restrike standby relay module « Reply #2 on: October 21, 2018, 07:03:26 AM » Author: sol
Ok, thanks. I don’t plan on exceeding the maximum wattage indicated on the relay, which would typically be at least 200 watts. I will probably use a standard incandescent lamp of either 60 or 100 watts.
