form109
i would install....
1000 watt mercury vapor cooper ovl's in parking lots
400 watt mercury vapor cooper ov-25's for illuminating the main roads
175 watt mercury vapor nema buckets for illuminating side streets
what would you guys install.mercury vapor is my prefrence but you can install any hid light source you choose,you can also choose any brand and model of luminare made after 1980.
gmercury2000
Not bad choices but you can no longer install MV fixtures, also one thing to keep in mind is the people affected by the lighting.
Anyways as for the NEMA's I would love the idea but most likely use MH, a bit more pricy but much better light color that HPS.
form109
okay,then i would use ceramic metal halide lamps. ![Smiley :)](/Smileys/default/smiley.gif)
gmercury2000
Nice, that works! ![Wink ;)](/Smileys/default/wink.gif)
form109
cool,but metal halide lamps in general come in multiple color tempatures,of course 4000-4200k is the most common but why not use cmh lamps as low as 2700k or as high 20,000k,ceramic metal halide lamps present us with the ability to pick our favorite color,and btw i would also install....
400 watt cmh M-400-R2'S
400 watt cmh M-400-R3'S
400 watt cmh Model 125
also i would install some cmh ovx's and ovd/ovy's
however i would not install durastars
GE M-400A1
![](https://www.lighting-gallery.net/index.php?PHPSESSID=82804d0eed51c1c639c9bce156ecdaee&action=dlattach;attach=136;type=avatar)
My Pontiac 6000 STE
All HPS ![Grin ;D](/Smileys/default/grin.gif) !
My Cars:
1986 Pontiac 6000 STE
1996 Chrysler Concorde LXi
1998 Chrysler Cirrus LXi
form109
prawnman88
![](https://www.lighting-gallery.net/index.php?PHPSESSID=82804d0eed51c1c639c9bce156ecdaee&action=dlattach;attach=185;type=avatar)
my old friend proteus the prawn!
id istall gumballs and teardrops everywhere ![Smiley :)](/Smileys/default/smiley.gif) merc or ceated mh no hps
form109
those would have to be repo teardrops/gumballs made after 1980
TudorWhiz
320 watt Pulse start MHs in parking lot 175 watt MH or CMH NEMA heads with refurbished gumball lens and older fittings for most residential roads 250 Pulse or probe start watt MHs for main roads 50 watt or LED's for walkways any source of lamps 200 watt or lower for private residential property any source of lamps 400 watt or lower for private commercial property 1000 watt MH lamps are limited option and must be reasonable because they are OVERKILL! Any private property or residential asking for HPS will be charged extra
form109
If I was in charge, I'd probably install 175 watt metal halide fixtures on residential streets and use 400 watt metal halide for the main roads.
form109
that is a good idea..but it would be made possible once metal halide lamps improve a whole lot!
lightman64
![](https://www.lighting-gallery.net/index.php?PHPSESSID=82804d0eed51c1c639c9bce156ecdaee&action=dlattach;attach=212;type=avatar)
Id retrofit all the HPS lights with Ceramic Metal Halide conversion lamps!
form109
now there's an idea,cause then you wouldnt have to buy new ballasts or fixtures...so its cost effective!
lightman64
Yeah, I didn't even think about that! And they would have better color!
