Author Topic: Lead wires on NEMA light  (Read 2110 times)
Lead wires on NEMA light « on: August 11, 2018, 04:26:53 PM » Author: Cole D.
My GE NEMA head on the ends of the wires had blue heat shrink like tubing on it. Was this where the supply wires were connected to it? I'm assuming it's okay to just use a wire strippers to strip this back so I can attach a cord.
589
Tha SOX MADMANNN
Re: Lead wires on NEMA light « Reply #1 on: August 14, 2018, 08:41:53 AM » Author: 589
I see this done with unused taps on a multi tap ballast to keep the unused taps from shorting out. Make sure you are using the correct taps off of the ballast.
:lps:
