Author Topic: My Line Voltage is a bit different from normal.  (Read 5964 times)
MissRiaElaine
Re: My Line Voltage is a bit different from normal. « Reply #15 on: August 03, 2018, 09:56:53 AM » Author: MissRiaElaine
Wow! The voltage in my room at my hostel, was 208V only at 16:45, and the UPS boost it by 30V to 238V to my computer.
Wow, that is low, does it get down to that level often..? How far are you from the substation..? We are literally next door to ours, so our voltage is always up at around 245-247V.
Re: My Line Voltage is a bit different from normal. « Reply #16 on: August 03, 2018, 10:13:26 AM » Author: dor123
The only substation near Kiryat Ata, located near the square of Zevulun street and the industrial park of Kiryat Ata: Picture
Re: My Line Voltage is a bit different from normal. « Reply #17 on: August 03, 2018, 10:15:29 AM » Author: Mandolin Girl
How far away are you from it..? Is your line voltage usually this low..?
Re: My Line Voltage is a bit different from normal. « Reply #18 on: August 03, 2018, 10:17:46 AM » Author: Mandolin Girl
Wow! The voltage in my room at my hostel, was 208V only at 16:45, and the UPS boost it by 30V to 238V to my computer:
Nice that you can have monitoring software for your UPS, our one refuses to synchronise with the PC so we ware going to get a decent UPS next year.
Re: My Line Voltage is a bit different from normal. « Reply #19 on: August 03, 2018, 11:27:26 PM » Author: ace100w120v
At my house it varies wildly; 92v isn't unheard of at my place.
Re: My Line Voltage is a bit different from normal. « Reply #20 on: August 04, 2018, 12:49:18 AM » Author: dor123
I asked an electrician of the IEC that read the electrical meter, and he said that the input voltage is correct at 230V, so this is only in my room that I've such low voltage.
At my former hostel at Lilenblum 13, I had 230V average. It is at my current hostel at Zalman Shne'ur 24, I've such low voltages. Both streets aren't so far from the substation near the square at the beginning of Zevulun street and at the entrance of Kiryat Ata.
Re: My Line Voltage is a bit different from normal. « Reply #21 on: August 04, 2018, 05:17:23 AM » Author: Medved
Then there is very likely an open Neutral problem developing in that building...
Re: My Line Voltage is a bit different from normal. « Reply #22 on: September 12, 2018, 09:45:53 PM » Author: icefoglights
Where I grew up, the house was fed by a neighborhood transformer, through less than ideal underground wiring.  I think we typically had 110-115V.  Current house, which is directly connected to a transformer on a pole shared with 2 other houses, is dead on 120V.  It was enough of a difference after moving that I started buying long life 60w bulbs for my bedroom light because standard ones burned out too frequently.
Another place I lived shared a small substation with a dozen other houses and a saw mill.  The voltage dips whenever the mill started equipment would cause the UPS I had to frequently kick over to battery power, and eventually wore the contactor out.  Got real annoying when I'd try to use my computer and it would randomly cut off dead.
lightinglover8902
GoL UCfoxh9h5FaLg-R04V8WDi3w
Re: My Line Voltage is a bit different from normal. « Reply #23 on: September 12, 2018, 11:14:43 PM » Author: lightinglover8902
The power voltage in my house is normally 121v to 123.5v, its not perfect 120v. It does fluctuate.
Re: My Line Voltage is a bit different from normal. « Reply #24 on: September 13, 2018, 04:46:25 AM » Author: dor123
My voltage in my room at my new hostel is 216-220V now:
Yesterday it was 220-230V
« Last Edit: September 13, 2018, 04:48:13 AM by dor123 » Logged
