Author Topic: roadway luminares stamped vs cast  (Read 8106 times)
form109
roadway luminares stamped vs cast « on: August 02, 2008, 10:33:42 PM » Author: form109
most earlier streetlights were either stamped or cast as time progressed cast became the dominate material for luminares.
benifits of stamped aluminimum fixtures(such as the form 400,and early ov-20,josyln cobraheads)
its lighter
easier to manufacture
cheaper to manufacture
disadvantages of stamped aluminimum fixtures.
damaged relatively easier
physically weaker
advantages of cast aluminimum fixtures(such as later ov-20's and the ov-35,and hma-60,m-400)
stronger
adds durability,harder to damage
disadvantages of cast aluminimum fixtures.
hevier
cast aluminimum doesnt bend but a very hard impact will shatter it
more expensive to manufacture
harder to make(as the casting molds have to be changed out every few thousand molds to prevent defects in the metal)
« Last Edit: August 02, 2008, 10:35:21 PM by form109 » Logged
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: roadway luminares stamped vs cast « Reply #1 on: August 08, 2008, 10:40:06 PM » Author: Foxtronix
In the past, companies makes strong and high-quality products: a M400 dropped from 30ft. even won't break! (I think) Try this with a modern M400A3...
form109
Re: roadway luminares stamped vs cast « Reply #2 on: August 08, 2008, 10:59:37 PM » Author: form109
 that depends on what it falls on,if it falls on grass it probably will be okay,but i think damage will be inflicted if it fell on a hard surface such as pavement,concrete,ect.
« Last Edit: August 08, 2008, 11:01:32 PM by form109 » Logged
Foxtronix
Re: roadway luminares stamped vs cast « Reply #3 on: August 08, 2008, 11:12:30 PM » Author: Foxtronix
That's sure that the glass lens will shatter on the concrete! Maybe not the metal...
form109
Re: roadway luminares stamped vs cast « Reply #4 on: August 09, 2008, 11:40:18 AM » Author: form109
how strong the cast aluminimum depends on how strong the mold is any defect in the mold will show up in the metal,which is why casting molds are changed every few thousand molds,cast metal is strong but it will break,and im not sure about it surviving a 30 ft drop intact.
lite_lover
Darren
GoL darren.harward
Re: roadway luminares stamped vs cast « Reply #5 on: August 09, 2008, 02:51:11 PM » Author: lite_lover
The fixture would have to land on soft ground to survive, especially with the extra weight of the ballast.Sometimes even a minor impact, will cause the fixture to break off from around the slipfitter area. Depending on the wiring and fixture type,it will be hanging by the wires or pull apart from the wiring harness and drop.
The brighter the better.
