Author Topic: Are Sylvania HID bulbs worth buying?  (Read 3713 times)
Are Sylvania HID bulbs worth buying? « on: July 21, 2018, 07:21:59 PM » Author: Cole D.
Just wondering because Lowes still has some on clearance, 175W clear MV for $4. I was thinking of getting one for my GE 201SA, to compare to the coated one it came with.
takemorepills
Re: Are Sylvania HID bulbs worth buying? « Reply #1 on: July 21, 2018, 09:35:00 PM » Author: takemorepills
$4? Should be a no-brainer! Buy it! Even if it isn't a "good" HID bulb, you can't beat $4.
Re: Are Sylvania HID bulbs worth buying? « Reply #2 on: July 22, 2018, 12:30:22 AM » Author: Lumex120
My Lowe's has those too. And yes, I'd say they are worth it.
Unofficial LG Discord
Re: Are Sylvania HID bulbs worth buying? « Reply #3 on: July 22, 2018, 12:59:54 AM » Author: RyanF40T12
out of the big three, I'd have to say Sylvania makes the best right now and has for quite awhile.  GE and Philips don't seem to last as long.
BlueHalide
Re: Are Sylvania HID bulbs worth buying? « Reply #4 on: July 22, 2018, 06:39:13 PM » Author: BlueHalide
Sylvania has used its current chinese mercury lamp mfg since about 2012, I installed several in 2013 at a campground (in 175w nema buckets) and as far as I know all but one are still working, so its safe to say they last at least the rated 24,000 hours. One thing is certain though, the phosphor coat on the DX lamps degrades rapidly, those same lamps at that campground greened out only a few months after installation. But 90% of them have lasted 5 years now dusk to dawn, which is something
Re: Are Sylvania HID bulbs worth buying? « Reply #5 on: July 23, 2018, 08:50:30 PM » Author: Cole D.
Thanks guys, I bought one of them. They had Sylvania MH bulbs for $10, HPS for $5 and 300W incandescent for 94 cents also.
Re: Are Sylvania HID bulbs worth buying? « Reply #6 on: August 03, 2018, 03:48:48 PM » Author: Lumex120
I have a 250w version in my garage lowbay that's been getting use since 2014 and it still isn't turning green.
mefurd98
Re: Are Sylvania HID bulbs worth buying? « Reply #7 on: August 26, 2018, 01:59:45 AM » Author: mefurd98
 My local Lowe’s has switched to mostly GE products and has put the remaining Sylvania products on clearance. I picked up a 175w mercury and a 400w metal halide for about $10.
Re: Are Sylvania HID bulbs worth buying? « Reply #8 on: August 28, 2018, 09:52:28 AM » Author: Mandolin Girl
I wish we had the opportunity to buy these over here.  :'(
Re: Are Sylvania HID bulbs worth buying? « Reply #9 on: August 29, 2018, 08:41:17 PM » Author: Cole D.
I went back and got another MV bulb plus a 300W incandescent.
Re: Are Sylvania HID bulbs worth buying? « Reply #10 on: September 22, 2018, 06:31:14 PM » Author: Mandolin Girl
You're lucky that you get a choice of what lamp type you can buy, over this side of the pond it's 90% LED with the rest CFL or Halogen, nothing else seems to be stocked any more  :'( :'(
And CFL and halogens have now been banned from being made so it will be LED or candles soon. :'(
Re: Are Sylvania HID bulbs worth buying? « Reply #11 on: October 27, 2018, 06:08:00 PM » Author: Cole D.
Interestingly, I went to Habitat and they had some Sylvania HID bulbs. There was a 175W MV, 150W HPS and 100W HPS plus two Feit 80W MV. They all had Lowes' clearance stickers on them still, so I guess Lowes took the leftover ones there for some reason. They were $2 each plus they had a lot of LED bulbs with C7 base from Lowes too.
