Author Topic: Anyone know what is this device?  (Read 3221 times)
Anyone know what is this device? « on: June 19, 2018, 05:59:39 AM » Author: dor123
It is located at the storage of Carmel hospital:
It have a color changing LED indicator.
What is this device?
MissRiaElaine
Re: Anyone know what is this device? « Reply #1 on: June 19, 2018, 06:14:24 PM » Author: MissRiaElaine
Looks like a WAP (Wireless Access Point). I must admit I like the label, I misread the CR AP bit at first sight  :D
Cisco is usually good kit, though. What is the power brick for..? The unit is obviously powered up so I'm guessing it's powered via PoE (Power over Ethernet) so not sure why a power supply is there.
« Last Edit: June 19, 2018, 06:17:07 PM by MissRiaElaine » Logged
Re: Anyone know what is this device? « Reply #2 on: June 19, 2018, 06:56:59 PM » Author: RyanF40T12
Cisco prefers you use those power bricks with their WAPs.  Especially for long runs from the switch.
Re: Anyone know what is this device? « Reply #3 on: June 20, 2018, 01:43:02 AM » Author: dor123
Is WAP is similar to Router, but in a LAN instead of the internet?
MissRiaElaine
Re: Anyone know what is this device? « Reply #4 on: June 20, 2018, 09:46:44 AM » Author: MissRiaElaine
WAP = Wireless Access Point - it is a device to allow wireless devices access to the network and/or the internet. Most routers have one built in, but if you have a wide area to cover, such as a hospital, you would need several of these at strategic points around the site.
MissRiaElaine
Re: Anyone know what is this device? « Reply #5 on: June 20, 2018, 09:51:45 AM » Author: MissRiaElaine
That only works if you have power sockets where you need them. I had several (around 5 or 6 IIRC) Cisco Aironet WAP units around a site I worked at once. They were all powered over Ethernet simply because in the roof space of a large open warehouse-type structure, there were no power sockets.
In any case, I like equipment powered from sources I have control over. Plugging WAPs in locally means some idiot might switch them off. If they're wired back to the rack and powered from a UPS-backed switch or power injector, they're not likely to be switched off without me knowing about it..!
« Last Edit: June 20, 2018, 09:55:01 AM by MissRiaElaine » Logged
Re: Anyone know what is this device? « Reply #6 on: June 20, 2018, 08:19:08 PM » Author: RyanF40T12
We plug in the bricks at the same location that the router and telco equipment is at.  At the power brick, 1 CAT-5 line goes to the router, the other line goes to the WAP.  We use these in my church buildings.
MissRiaElaine
Re: Anyone know what is this device? « Reply #7 on: June 21, 2018, 06:18:55 AM » Author: MissRiaElaine
That's using power injectors and the WAP is fed power over the Ethernet link. That's fine, if you only have one or two devices. I meant using power bricks at the same location as the WAP and plugging it in directly. Firstly, it's not always possible as there isn't a power socket nearby, and secondly as I said, some idiot might switch it off.
I use a switch with PoE built in, that way I don't need a power injector for each device. At home, I only have a couple of IP phones, but when I was at work we had loads of devices all over the place so a separate power brick for each one would have been unmanageable.
By the way, Cat 5 is a bit out of date now, you might want to think about using Cat 6, or at the very least 5e.
« Last Edit: June 21, 2018, 11:09:53 AM by MissRiaElaine » Logged
Re: Anyone know what is this device? « Reply #8 on: June 24, 2018, 04:12:04 PM » Author: HomeBrewLamps
Looks like there is an old telephone back plate on the wall..
~Owen
Re: Anyone know what is this device? « Reply #9 on: June 24, 2018, 05:02:21 PM » Author: Cole D.
I see these on the ceilings of stores sometimes. Plus sometimes with antennas.
Re: Anyone know what is this device? « Reply #10 on: June 24, 2018, 06:40:06 PM » Author: RyanF40T12
We don't need anything right now that the 5e supports so they'll use the regular 5 cable that was installed years ago.
