Author Topic: Making a metal arm from a piece of conduit for a streetlight  (Read 2206 times)
lightinglover8902
GoL UCfoxh9h5FaLg-R04V8WDi3w
Making a metal arm from a piece of conduit for a streetlight « on: June 07, 2018, 04:24:26 PM » Author: lightinglover8902
I was just thinking of this, I was considering to maybe making a metal arm from a piece of conduit for a streetlight. Maybe around 1 1/4 inch diameter should do with a bender. Would it work, or would it not work, because EMT conduit is a bit stronger (correct me if I'm wrong) which could hold the fixture's weight. Just saying, its a good idea.
Re: Making a metal arm from a piece of conduit for a streetlight « Reply #1 on: June 08, 2018, 01:28:32 PM » Author: wattMaster
I would be concerned about it bending if you use an extra-heavy fixture, but it would probably work for a little one.
