Author Topic: Dozens of LED streetlights flashing  (Read 4969 times)
BlueHalide
Dozens of LED streetlights flashing « on: April 08, 2018, 12:33:34 AM » Author: BlueHalide
Was driving through northern Chicago tonight on I90 (which is now 100% LED), I drove through about a 1/4 to half mile stretch of freeway in which all of the LED cobraheads were flashing like strobes, like maybe 50-60 fixtures all flashing randomly. I thought it looked really bizarre, as every single fixture in that 1/2 mile bank of lights was doing that. Anybody have ideas as to what was going on? I know many of the modern LED streetlights have an on-board computer that communicates with the utility like our smart meters on our homes, could that be whats failing? If it was a mains electrical issue/transient on one phase, then all lights would flash in unison, not randomly
Re: Dozens of LED streetlights flashing « Reply #1 on: April 08, 2018, 12:58:34 AM » Author: HomeBrewLamps
Party lights!  ;D
Re: Dozens of LED streetlights flashing « Reply #2 on: April 08, 2018, 03:45:42 AM » Author: Roi_hartmann
Maybe it was one of those roads that has "emergency mode" on streetlights to notify drivers of nearby emergency vehicle. I remember someone linked a story of something like that on here some time ago.
Re: Dozens of LED streetlights flashing « Reply #3 on: April 08, 2018, 05:11:41 AM » Author: dor123
Either lost neutral or a brownout. I don't think that all of the LED lanterns flashing because all of them are EOLED. See here and here
Re: Dozens of LED streetlights flashing « Reply #4 on: April 08, 2018, 02:36:18 PM » Author: RyanF40T12
It's a result of a power hit.  Meaning it's lost a phase or something causing a reduction in power to get to the fixtures.  We see it every once in awhile here, when there is an underground wire fault of some sort.
d3anio97
Enginerding bright things since 2011
ATL TheSOXMania
Re: Dozens of LED streetlights flashing « Reply #5 on: April 08, 2018, 04:07:28 PM » Author: d3anio97
This is a super common issue and it's linked to the power supplies. LED street lights use HF switchmode power supplies with feedback loops to their controllers. All it takes is one component to fail on the feedback line and you have a flashing lantern. This is the biggest reason why LED is total (...) for outdoor lighting and should be limited to municipal and indoor.
What if I told you you could save 100% of your street lighting budget? Don't believe me? Buy an LED street light and run it for a week. the results will leave you in awe. (Aaaaaaand maybe wondering why you swapped that 70w SON)
Re: Dozens of LED streetlights flashing « Reply #6 on: May 09, 2018, 01:40:42 PM » Author: Medved
The offending failure is most likely not even inside of the ballasts, but in the installation wiring.
The difference towards classical magnetic ballasts is, the magnetic ballasts tend to increase the input current when the input voltage increases. In case it does not mean higher load power, nor higher losses, it causes higher reactive power. But the important tging is, the current increases. This inherent feature means, if some fault makes the system effectively running lanterns in series, it balances itself around some working stable equilibrium operating point, so everything still works at least somehow (even when the performance degrades, usually it is stable). The same is valid for many electronic ballasts for e.g. fluorescents and/or induction (when the ballast does not feature any constant power regulation)
The electronic ballasts on the other hand strictly maintain the output power and the input as high power factor resistor. That means if the input voltage rises, the input current drops. So it exhibits a form of a negative dynamic resistance in its characteristic.
The negative resistance means, the eventual equilibrium point does exist as well, but contrary to magnetic ballasts, with electronic it is unstable. That means volage across one ballast rises, across the other falls. The first then reduces its current, the other tries to increase it. But as the series combination always yield the same current (1'st Kirchhoff's law), the voltage across the second is dropping faster and faster, till it reaches the undervoltage shut down, so does the connected LED.
At that moment the ballast stops regulating, becomes rather high impedance on its input, so even the other ballast in the series string looses power and shuts down.
Then the voltage across it rises, till the ballast restarts, so again you get an unstable condition with two ballasts, so the cycle repeats, hence the flashing.
The explanation above was made on a simple example of just two ballast in series. In real installation (with many ballasts), with a real life fault (e.g. loose Neutral in multiphase supply system) the network is way more complex, but the instability is still there. Just the high amount of ballasts leads to high amount of state combinations they may achieve, so the flashing is no longer as regular as with the simple example.
