Author Topic: cold cathode flourescent lamp kits & ballast  (Read 2361 times)
form109
cold cathode flourescent lamp kits & ballast « on: July 25, 2008, 12:02:29 PM » Author: form109
go to www.allelectronics.com and look in the lamp section you will see several ccfl kits that include a one or two lamps in a variety of color and 12 volt inverters to run them
also look at www.goldmine-elec.com you will find some backlight flourescents and a magnetic flourescent ballast look in the lamp section.
while your are there check out the rest of their inventory as they sell wonderful surplus electric items!
electronic gold mine also sells a variety of small xenon strobe tubes,they also sell a large strobe tube that has a 1500 watt peak rating see here>http://www.goldmine-elec-products.com/prodinfo.asp?number=G16469
« Last Edit: July 25, 2008, 12:18:42 PM by form109 » Logged
lightman64
Re: cold cathode flourescent lamp kits & ballast « Reply #1 on: January 26, 2009, 06:46:04 PM » Author: lightman64
i have some cold cathode lamps in my basement. they are very interesting. i hope they don't go out because i dont know where to get more bulbs.
form109
Re: cold cathode flourescent lamp kits & ballast « Reply #2 on: March 14, 2009, 01:04:46 PM » Author: form109
well those stores above your post sell replacement CCFL kits if you need one.
