Author Topic: 1600 Watt Xenon Short Arc  (Read 11565 times)
Nineaclock
1600 Watt Xenon Short Arc « on: July 25, 2008, 08:55:14 AM » Author: Nineaclock
Click Here
Cool Video of a 1600 Watt Xenon getting fired up
form109
Re: 1600 Watt Xenon Short Arc « Reply #1 on: July 25, 2008, 09:52:39 AM » Author: form109
that lamp is a direct current model because one of the electrodes is bigger,very cool video ;D
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: 1600 Watt Xenon Short Arc « Reply #2 on: July 25, 2008, 10:15:25 AM » Author: Foxtronix
The lamp seems to be so bright!  8)
Nineaclock
Re: 1600 Watt Xenon Short Arc « Reply #3 on: July 25, 2008, 10:44:53 AM » Author: Nineaclock
24Volts DC with 65Amps to be exact
form109
Re: 1600 Watt Xenon Short Arc « Reply #4 on: July 25, 2008, 10:55:13 AM » Author: form109
to opperate that in my house i have to use the main breakers,65 amps can you imagine getting shocked by that,xenon short lamps are dangerous :o
Nineaclock
Re: 1600 Watt Xenon Short Arc « Reply #5 on: July 25, 2008, 11:07:05 AM » Author: Nineaclock
Ya you need a huge Inductor ballast, with a Huge Igniter. These lamps need anywhere from 50,000 to 70,000 Volts to ignite it.They work at amazing 70 Atmosphere,and the arc temp can range at up to 10,000°C, or 18,032F
« Last Edit: July 25, 2008, 11:10:53 AM by Nineaclock » Logged
form109
Re: 1600 Watt Xenon Short Arc « Reply #6 on: July 25, 2008, 09:38:14 PM » Author: form109
these lamps are dangerous even when switched off.
Foxtronix
Re: 1600 Watt Xenon Short Arc « Reply #7 on: July 26, 2008, 05:30:45 PM » Author: Foxtronix
Dangerous for sure! These lamps have much higher pressure than a HPS lamp (I think)...
FGS
Rory Mercury!
Re: 1600 Watt Xenon Short Arc « Reply #8 on: July 26, 2008, 07:09:50 PM » Author: FGS
What about the mercury ones of the similar shape. Are those dangerous when off? Theyre called HBO lamps. (Not the channel.)
Foxtronix
Re: 1600 Watt Xenon Short Arc « Reply #9 on: July 26, 2008, 07:58:51 PM » Author: Foxtronix
Depends of the pressure of the lamp: Higher=more exploding, that's simple  ;)
form109
Re: 1600 Watt Xenon Short Arc « Reply #10 on: July 26, 2008, 08:02:46 PM » Author: form109
both xenon and xenon-mercury short arc lamps are dangerous,they both have gasses under high pressures(5 atmospheres when switched off,90 atmospheres when powered.)of course the mercury-xenon lamp contains mercury so that technically makes it more dangerous,but on the bright side the mercury raises the luminous efficency.
Nineaclock
Re: 1600 Watt Xenon Short Arc « Reply #11 on: July 26, 2008, 11:23:29 PM » Author: Nineaclock
HBO do not contain Under pressure Gas when off, how ever they do create about 70 to 80 Atmospheres of Mercury Pressure so don't bump it when its on, how ever XBO lamps need Xenon under pressure to create is lights. Keep in mind HBO only contain Mercury at low pressure gas.
http://www.lamptech.co.uk/Spec%20Sheets/Osram%20HBO3500.htm  That should help you understand about the gas pressure in it a little better. :) The key factor in HBO lamps is not always visible lights, its the UV they alot of people are looking for Lab tech equipment. Buy the way (Form109) There is no Xenon-mercury short arc, HBO lamps only contains Argon and mercury at low pressure at room temperature when stable.The mercury Vapor pressure condenses back in to its original equilibrium state of energy to a stable room temperature to a solid.
« Last Edit: July 26, 2008, 11:37:12 PM by Nineaclock » Logged
form109
Re: 1600 Watt Xenon Short Arc « Reply #12 on: July 26, 2008, 11:37:53 PM » Author: form109
then explain how a xenon short arc lamp can explode when powered off,there is still some pressure present even when powered off.
Nineaclock
Re: 1600 Watt Xenon Short Arc « Reply #13 on: July 26, 2008, 11:40:22 PM » Author: Nineaclock
Yes theres always Pressure in Xenon short arc (XBO) but HBO are little different. The pressure changes due to Temperature as to alot of matter does. :)
form109
Re: 1600 Watt Xenon Short Arc « Reply #14 on: July 26, 2008, 11:42:59 PM » Author: form109
@nineaclock thanks :)
