Author Topic: LED bulbs flicker in operation????  (Read 2985 times)
lightinglover8902
GoL UCfoxh9h5FaLg-R04V8WDi3w
LED bulbs flicker in operation???? « on: February 20, 2018, 08:52:10 PM » Author: lightinglover8902
When I was at my desk soldering some stuff, I notice that my LED lamps are flickering a bit. I don't know if its the driver picking up some AC modulation or may go EOL or capacitor in the driver ballast, making it flicker. What do you think it may be? Did your LED bulbs do a bit of flickering, while in operation? Also CFLs do that flicker too.
Re: LED bulbs flicker in operation???? « Reply #1 on: February 20, 2018, 09:22:03 PM » Author: sol
The only lamps that I commonly use that show no visible flicker (to me anyways) are incandescent run straight on the mains, fluorescent on a properly functioning electronic ballast and HID on electronic ballast, after warmup is complete. Otherwise, I can notice quite easily flicker in just about any other source, from neon indicators, LED, magnetically ballasted anything, incandescent that operates on certain photocells (night lights) or diode dimmers (socket that has high-low-off). Sometimes annoying but mostly inoffensive. The worst culprit has been extensively discussed under LED Christmas lights threads. Anyways getting off topic here...
Re: LED bulbs flicker in operation???? « Reply #2 on: February 20, 2018, 09:22:58 PM » Author: sol
Oh, and no flicker on incandescent and LED run from DC.
Re: LED bulbs flicker in operation???? « Reply #3 on: February 21, 2018, 02:39:28 AM » Author: dor123
Most of the cheap LED fixtures and floodlights I've seen here, flickering, sometimes badly .
Re: LED bulbs flicker in operation???? « Reply #4 on: February 21, 2018, 02:43:20 AM » Author: Ash
Some LED lamps have no capacitors in the drivers, or capacitors with too low volume to prevent flicker. In theory this does not pose a problem, as 100/120 Hz flicker is invisible and LEDs dont have all the stuff like like restrike after zero crossing (a reason why capacitor is really needed in HF discharge ballasts)
Some LED lamps have a driver design that does not do any "conversion", instead, it shorts out sections of a long array of LEDs to match the momentary voltage point on the sine wave at any time, so there the flicker is part of the ballast operation
However, here the theory ends. LED flicker can be squarewave (vs. more gradual in discharge) and the duty cycle of the flicker can be much shorter "on" periods (vs. discharge). Flicker at 100/120Hz is borderline between visible or not. It is exactly this detail (and for Fluorescetnts, the afterglow of the Phosphors) that makes the difference...
Fully flicker free lighting is either Fluorescent with proper HPF electronic ballast (one that uses boost converter, not any "valley fill" or so) and low voltage Halogen lighting (the thick filament have high thermal inertia)
Re: LED bulbs flicker in operation???? « Reply #5 on: February 21, 2018, 03:40:30 AM » Author: Medved
The theory does not end there at all. The literature describes pretty accurately, how the border frequency (when the flicker becomes below certain perception level) depends on the shape of the light output pulse. And it lists the acceptable flicker level for given applications (it includes the way, how the light is gonna to reach the eye - peripheral vision is way more flicker sensitive than the central vision part, so accent light has higher flicker tolerance than base light background, driveway security light has higher acceptable flicker than indoor lighting,...).
The problem is, many LEDs are designed according to the most flicker tolerant applications (low quality lighting), but offered for rather high demand applications.
This belongs to the general problem of wrong specification of the exact used light source.
The technical problem is, you may have flicker free lamp within a tight enclosure (the filament concept), but then the ballast life will be rather limited (the highly loaded capacitor will fail first, most likely causing short circuit; but for high light quality application it still may be acceptable).
You may as well design the ballast to really eliminate all life limiting components (so mainly the electrolytes; so the overall life would be really limited by the LED alone, which is unavoidable), the money saved on those you may put into using more LED chips and drive them at lower power so prolong their life, but then you have to live with some flicker.
