Author Topic: older mercury vapor lamps and flickering  (Read 4217 times)
form109
older mercury vapor lamps and flickering « on: July 24, 2008, 12:10:08 PM » Author: form109
i notice some older mercury vapor lights in my neighborhood flicker on and off many times,before a stable arc is struck,besides old age what causes this?
don93s
Re: older mercury vapor lamps and flickering « Reply #1 on: July 24, 2008, 10:37:22 PM » Author: don93s
From what I know, as the lamp ages, the electrodes become depleted of emitter and cause an unstable arc when first started. Sometimes, if there is excessive sputter on the quartz walls, the sputtered metals will also conduct current causing the arc to jump around in the arc tube at first. Also, the electrodes might start to glow brightly in incandescence (sort of like fluorescent filaments when old).
form109
Re: older mercury vapor lamps and flickering « Reply #2 on: July 24, 2008, 10:46:09 PM » Author: form109
just a thought if a mercury vapor lamp has very high hours on it does it reach full tempature,and pressure.
GE M-400A1
My Pontiac 6000 STE
Re: older mercury vapor lamps and flickering « Reply #3 on: July 28, 2008, 08:23:43 PM » Author: GE M-400A1
no.
My Cars:
1986 Pontiac 6000 STE
1996 Chrysler Concorde LXi
1998 Chrysler Cirrus LXi
don93s
Re: older mercury vapor lamps and flickering « Reply #4 on: August 03, 2008, 12:54:59 PM » Author: don93s
From what I have tested, it seems that MV still does reach full pressure and temperature, as they still draw the same wattage.....and they have to reach full pressure to draw full wattage. If anything, they may even run hotter since the arc tube blackens and absorbs some of the energy as heat.
form109
Re: older mercury vapor lamps and flickering « Reply #5 on: February 23, 2009, 08:50:39 PM » Author: form109
Don,you are absolutely right,i've observed this in one of my regent lamps that was accidently connected to mains,the current severly darkened the arctube but the lamp was still functional,the blackened area's glow Red Hot when the lamp is shut off,so your conclusion is correct,Thanks!
