Author Topic: 32Watt CFL Plugin  (Read 4117 times)
Nineaclock
32Watt CFL Plugin « on: July 24, 2008, 07:53:52 AM » Author: Nineaclock
CLICK HERE!! VIDEO
The description in the information in the top right.Also note my camera was about to die, so I had to put it on low color quality, so its got a big glare to it.
« Last Edit: July 24, 2008, 07:57:45 AM by Nineaclock » Logged
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Re: 32Watt CFL Plugin « Reply #1 on: July 25, 2008, 10:18:04 AM » Author: Foxtronix
Nice. Your yard seems well lit. Mine is lit by three 14W GE buglite (CFL), a total of 42W and all the yard is lit.
Nineaclock
Re: 32Watt CFL Plugin « Reply #2 on: July 25, 2008, 10:40:54 AM » Author: Nineaclock
Thanks, I molded a standard Fixture that I got from lowes. I cut the top out to where I could accesses the base screw where the bulb goes. and put in a 4-Pin GX24q-3 Base. Then I welded the top together. I can run another fixture and bulb that would hook up to the same Ballast, its a duel support 32 watt ballast. Here Thats a link to the ballast information. Buy the way The ballast is sitting in a Old ammunition box that you can find form the surplus, I drilled a couple holes for the duel tap wires.
« Last Edit: July 25, 2008, 10:57:18 AM by Nineaclock » Logged
