Author Topic: Cycling Flourscent  (Read 4280 times)
GE M-400A1
My Pontiac 6000 STE
Cycling Flourscent « on: July 23, 2008, 07:43:41 PM » Author: GE M-400A1
My Ge Flo. Tube will run for about five minutes then go into a cycling mode and if i let it cool for a while it does it all over again. I dodn't think flo. tubes cycled!!
Thanks
My Cars:
1986 Pontiac 6000 STE
1996 Chrysler Concorde LXi
1998 Chrysler Cirrus LXi
TudorWhiz
Re: Cycling Flourscent « Reply #1 on: July 24, 2008, 02:50:17 AM » Author: TudorWhiz
Got a video?
GE M-400A1
My Pontiac 6000 STE
Re: Cycling Flourscent « Reply #2 on: July 24, 2008, 02:09:21 PM » Author: GE M-400A1
I will take one this evening!
My Cars:
arcblue
Re: Cycling Flourscent « Reply #3 on: July 25, 2008, 12:22:36 AM » Author: arcblue
Sounds like ballast failure or overheating is causing the thermal protector ("P" rated ballast) to cut off the ballast when it reaches a certain temperature, then switch back on about 5 min later when it's cooled down. Usually is a ballast problem, but sometimes a bad lamp, extremely hot ambient temperature, etc. can cause the cycling.
I'm lampin...
GE M-400A1
My Pontiac 6000 STE
Re: Cycling Flourscent « Reply #4 on: July 28, 2008, 12:39:53 AM » Author: GE M-400A1
I don't think it is the thermal switch becuase it just turns on and then dies and starts right back up in a second  again and it still does it for a while.
My Cars:
Mr. Big
Re: Cycling Flourscent « Reply #5 on: July 30, 2008, 08:47:47 PM » Author: Mr. Big
Sounds like a classic example of a worn out preheat lamp!
Is it kinda like this? http://www.youtube.com/watch?v=mypM435y6lE
GE M-400A1
My Pontiac 6000 STE
Re: Cycling Flourscent « Reply #6 on: July 30, 2008, 10:08:59 PM » Author: GE M-400A1
Thanks Mr.Big! I also got the second one and that one will run!
Glad you can help!
My Cars:
don93s
Re: Cycling Flourscent « Reply #7 on: August 03, 2008, 12:57:41 PM » Author: don93s
The only time I've seen a fl. lamp cycle was when there was a loose metal wire inside the end cap. When lamps heats up, it acts as a bi-metal switch, and breaks contact.
GE M-400A1
My Pontiac 6000 STE
Re: Cycling Flourscent « Reply #8 on: August 03, 2008, 02:09:12 PM » Author: GE M-400A1
Never heard of that!
My Cars:
