Author Topic: Does LG seem slow today?  (Read 5767 times)
lightinglover8902
GoL UCfoxh9h5FaLg-R04V8WDi3w
Does LG seem slow today? « on: January 14, 2018, 11:21:24 PM » Author: lightinglover8902
Once I get on at LG, it takes like 20 seconds, or more to get on. Are you having that same problem, that I'm having?
Re: Does LG seem slow today? « Reply #1 on: January 14, 2018, 11:26:35 PM » Author: HomeBrewLamps
No, Probably Network issues on your side, or possibly your computer needs a restart (mine does need that as well sometimes).
~Owen
MissRiaElaine
Re: Does LG seem slow today? « Reply #2 on: January 15, 2018, 11:29:46 AM » Author: MissRiaElaine
If you're running Windoze, it probably needs a size 12 boot up its backside  :D :D :D
FGS
Rory Mercury!
Re: Does LG seem slow today? « Reply #3 on: January 15, 2018, 12:55:41 PM » Author: FGS
Try size 13 for me. ;D
On a serious note. It's more than likely just networks bellyaching over this and that. I get the occasional slow websites to load even on iOS. Too many people using the same site bogging down the servers it's in. And no, Linux won't cure it. It's not on the user's end so either deal with it or try again later. Give the router in your house a size 13 up its rear end if it persist. Unplugging power to it and back on usually fixes it.
MissRiaElaine
Re: Does LG seem slow today? « Reply #4 on: January 15, 2018, 01:23:29 PM » Author: MissRiaElaine
I'll go along with that, I usually have to give the router a prod every 4-5 weeks or so.
Lodge
Re: Does LG seem slow today? « Reply #5 on: January 15, 2018, 06:17:40 PM » Author: Lodge
Stop using factory firmware, use DD-WRT firmware and say hello to MESH capable networks and say good bye to restarting routers, and for the most part all you need to do is re-flash the firmware on your router, and I've seen old boot sale junk out do modern high priced stuff, I have a stock +10 year old WRT54G 2.0 Version router I paid $5 for. It will do WIFI for a mile with changes to the power levels in the control panel, and if the UPS battery didn't fail it's up-time would be almost four years..
If your going to play with old routers, Some of them also have what they like to call a non-user replaceable battery to keep the settings so crack them open and replace it if you find it having issues at any point after powering up.. I normally pull the little watch battery sized stock battery and drop in a SAFT LS14250 MLB battery and they are plugin style so if you ever need to change them it's simple plug and play but the odds of ever needing to change 1.2 Amp hour Lithium battery in a router in the next two decades is very small as they are about 6 times the capacity of the CR2032 it replaces...
MissRiaElaine
Re: Does LG seem slow today? « Reply #6 on: January 15, 2018, 06:37:53 PM » Author: MissRiaElaine
It works fine, I don't use wireless anyway, except for quick email alerts on the phone.
Here's my network rack, the router is out of shot as it's mounted next to the incoming line port and connected with gigabit cat 6 cable.
lightinglover8902
Re: Does LG seem slow today? « Reply #7 on: January 15, 2018, 06:51:52 PM » Author: lightinglover8902
Wow, what a server system, that you have.
589
Tha SOX MADMANNN
Re: Does LG seem slow today? « Reply #8 on: January 15, 2018, 08:19:12 PM » Author: 589
Geez that's that's a ton of storage. That's quite a smart looking network rack.
:lps:
Re: Does LG seem slow today? « Reply #9 on: January 15, 2018, 10:10:17 PM » Author: dor123
I've slowness in LG, when entering to someone gallery or to my gallery, or switching pages in my gallery. It takes more than a mins, often resulting in a Pale Moon error message that the connection was reset.
MissRiaElaine
Re: Does LG seem slow today? « Reply #10 on: January 16, 2018, 07:46:39 AM » Author: MissRiaElaine
It's not a lot, actually, by today's standards, somewhere around 3TB or so, but the drives are in a Raid 5 array which allows for a drive to fail and be replaced without losing data.
More details here and here.
Re: Does LG seem slow today? « Reply #11 on: January 16, 2018, 10:40:02 AM » Author: dor123
The website don't responding when I enter to someones gallery.
Edit: This has gone too far:
I just wanted to enter Lantern_Vision gallery:
« Last Edit: January 16, 2018, 10:45:36 AM by dor123 » Logged
Re: Does LG seem slow today? « Reply #12 on: January 16, 2018, 11:08:01 AM » Author: Mandolin Girl
It could be connection to your local server that's the problem. Are you having the same problem with other sites or is it just LG.
MissRiaElaine
Re: Does LG seem slow today? « Reply #13 on: January 16, 2018, 11:12:04 AM » Author: MissRiaElaine
@dor123
What version of windows are you using?
You might need to upgrade your OS
MissRiaElaine
Re: Does LG seem slow today? « Reply #14 on: January 16, 2018, 11:13:25 AM » Author: MissRiaElaine
It's been a bit slow for me today, but it depends on what the page is loading. If it's just text, it's not too bad, but a gallery photo is taking up to 10 seconds.
