Author Topic: runing two lamps on one ballast  (Read 2425 times)
form109
runing two lamps on one ballast « on: July 18, 2008, 04:25:56 PM » Author: form109
just wondering can you run two 50 watt mercury vapor lamps on a 100 watt metal halide ballast.
GE M-400A1
My Pontiac 6000 STE
Re: runing two lamps on one ballast « Reply #1 on: July 20, 2008, 01:49:04 AM » Author: GE M-400A1
You maybe able to but i would not because i don't want to take a chance at losing a ballast!
My Cars:
1986 Pontiac 6000 STE
1996 Chrysler Concorde LXi
1998 Chrysler Cirrus LXi
Re: runing two lamps on one ballast « Reply #2 on: March 24, 2009, 07:49:38 PM » Author: Medved
No, if you want both lamps as well as ballast survive it.
Parrot
YouTube: Parrot175
Parrot175 parrot175
Re: runing two lamps on one ballast « Reply #3 on: January 11, 2010, 08:05:55 PM » Author: Parrot
How would you wire that? In series or some other way? Because you only have one wire for one bulb or is it made for two bulbs?
Xytrell
Re: runing two lamps on one ballast « Reply #4 on: January 12, 2010, 01:02:26 AM » Author: Xytrell
well, if you wire them in series, the voltage drop is too much for the ballast. So the ballast will likely overheat. If you wire them in parallel, on the other hand, there's nothing to stop all the current from going to just one lamp. So only one will light, and then be driven at a full 100W until it blows.
So, as stated above, not a good idea.
