Author Topic: Daylights tube as a grow lamp.  (Read 10453 times)
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Daylights tube as a grow lamp. « on: July 17, 2008, 11:26:42 PM » Author: Foxtronix
If the Daylight tube really emit daylight spectrum, it can serve as a grow light, right?
form109
Re: Daylights tube as a grow lamp. « Reply #1 on: July 17, 2008, 11:29:11 PM » Author: form109
i guess so,what are you growing ;D
GE M-400A1
My Pontiac 6000 STE
Re: Daylights tube as a grow lamp. « Reply #2 on: July 17, 2008, 11:50:50 PM » Author: GE M-400A1
that's why they call it "daylight".
My Cars:
1986 Pontiac 6000 STE
1996 Chrysler Concorde LXi
1998 Chrysler Cirrus LXi
Foxtronix
Re: Daylights tube as a grow lamp. « Reply #3 on: July 18, 2008, 12:03:26 AM » Author: Foxtronix
Nothing (and no, I don't hide Cannabis  :P) but I was wondering about the Daylight capacity of replacing special Plant tubes.
form109
Re: Daylights tube as a grow lamp. « Reply #4 on: July 18, 2008, 12:11:20 AM » Author: form109
cannabis??
Foxtronix
Re: Daylights tube as a grow lamp. « Reply #5 on: July 18, 2008, 12:30:24 PM » Author: Foxtronix
marijuana if you want.
form109
Re: Daylights tube as a grow lamp. « Reply #6 on: July 18, 2008, 02:40:41 PM » Author: form109
no,not that i thought maybe you were trying to increase the growth of a house plant.
Foxtronix
Re: Daylights tube as a grow lamp. « Reply #7 on: July 18, 2008, 04:23:12 PM » Author: Foxtronix
I will surely try this someday, or a comparison of two plants, one under Daylight tube and the other under the special plant light for seeing the difference of growing.
don93s
Re: Daylights tube as a grow lamp. « Reply #8 on: July 19, 2008, 04:20:52 PM » Author: don93s
I've heard that the 5000k-5500k full spectrum lamps are better. They have more color spectrum than the daylight which are mostly strong in the blue. I have house plants growing good under some 40w Duro-test Vitalites.
GE M-400A1
My Pontiac 6000 STE
Re: Daylights tube as a grow lamp. « Reply #9 on: July 20, 2008, 01:52:26 AM » Author: GE M-400A1
Same as lighting for acuariums as well. But we use 10k flourscent lamps and double ended MH lamps. They make lt look blueish to siumlate the ocean and help grow acuatic plant life as well.
My Cars:
bryanrb
Re: Daylights tube as a grow lamp. « Reply #10 on: January 31, 2018, 08:05:27 PM » Author: bryanrb
I would use a 2 lamp shoplight or similar fixture. I would use a combination of Warm white(3000 or 3500k) and daylight tubes(6500k). It will help balance out the blues and reds on the Kelvin spectrum.
Re: Daylights tube as a grow lamp. « Reply #11 on: January 31, 2018, 10:36:42 PM » Author: RyanF40T12
I prefer these for grow lights
Re: Daylights tube as a grow lamp. « Reply #12 on: January 31, 2018, 11:45:27 PM » Author: Ash
If you use Triphosphor lamps, i guess mixing 6500K with 3000K/2700K would be quite similar to using 4000K lamps, as each of them is a mix of the same 3 Phosphor components to begin with
Plants vary, but most of them need "something" in the Blue end and "something" in the Red/Orange end. For the latter, HPS gives far more than you'd achieve with any FL. So maybe try Daylight FL + HPS. Maybe Blue or BL FL
takemorepills
Re: Daylights tube as a grow lamp. « Reply #13 on: February 01, 2018, 12:22:44 AM » Author: takemorepills
I have new F40T12D lamps (Philips I believe) and they are not the same bluish-white as older Daylight lamps. They are more of a higher CRI pure white. I think these would work perfectly as plant lights.
Re: Daylights tube as a grow lamp. « Reply #14 on: February 01, 2018, 07:19:24 AM » Author: dor123
Most people here, recommends warm white as a simple solution for plant grow.
Usually the red and the orange wavelength, are more important than the blue wavelengths.
