Author Topic: Compact Fluorescents?  (Read 5282 times)
shortee
Compact Fluorescents? « on: July 10, 2008, 07:33:38 AM » Author: shortee
 :P I am trying to hook up a 100 watt compact fluorescent with a mogul socket. Do I need a ballast or can I just hook it up to a plug that will carry the voltage? I have never hooked a light before although I dig the colors and moods. This would be the first time. I have had a few lamps before. Basically this is for a garden of tomatoes. I got sick from the salmonilla deal.
Re: Compact Fluorescents? « Reply #1 on: July 10, 2008, 07:20:14 PM » Author: icefoglights
If you look at the plastic base, it should have some writing on it.  If it says it's for 120 volts, lists its wattage, and its current (in A or mA) than it's probably self ballasting.  If not, it won't list its current, and will probably say only for use with a ballast.
After looking at that page, I'm going to guess it's self ballasting and you should be good to go.
shortee
Re: Compact Fluorescents? « Reply #2 on: July 11, 2008, 03:35:31 AM » Author: shortee
I have found a mogul socket for the screw base. It matched the voltage and it had a black and white wire. The mogul screw really throws me off because it's twice the size of a regular light bulb. I have no idea what the black and white wire are for. I guess to wire directly to the house or to ground through the house electrical wiring. I was hoping to wire it to a plug in grounded cord. Is that possible or what is the white and black wire for? I'm so sorry. I think it would be easier with a well known light but these CFL things are pretty new I guess.  :(
don93s
Re: Compact Fluorescents? « Reply #3 on: July 11, 2008, 01:29:52 PM » Author: don93s
If you say the socket already has a black and white wire, connect those to the black and white wire of the power cord. If you are using a grounding cord (recommended), the third green wire bolts to the metal fixture assembly. As a rule, the white wire (neutral) connects to the socket shell (threaded part) and the black (hot) connects to the socket center.
I'm assuming the wall-plug part is already pre-made. If not, the black goes to the smaller flat blade and the white goes to the larger flat blade. And the green goes to the third rounded prong.
shortee
Re: Compact Fluorescents? « Reply #4 on: July 11, 2008, 03:56:21 PM » Author: shortee
Oh crap. It looks self ballasted in the picture but I don't think it is. What kind of ballast would I need for two 100 watt compact fluorescents? Sorry....I just read a complaint from somebody who said that it looks self ballasted but actually is not.
« Last Edit: July 11, 2008, 05:32:45 PM by shortee » Logged
DimBulb
Re: Compact Fluorescents? « Reply #5 on: July 14, 2008, 06:52:01 AM » Author: DimBulb
I think your compact fluorescent is made to replace a Mercury Vapor bulb or some other type of bulb that uses a ballast. I don't think it's made to wire directly to 120V. That's why it would have a mogul base.
My very first word was LIGHT!
TudorWhiz
Re: Compact Fluorescents? « Reply #6 on: July 14, 2008, 10:20:30 AM » Author: TudorWhiz
I do know of Compact Fluorescent lights with mogul base made for 120 volts though..
TudorWhiz
Re: Compact Fluorescents? « Reply #7 on: July 14, 2008, 10:29:11 AM » Author: TudorWhiz
Shortee here is a reference for you
Webpage with plant growing CFL
shortee
Re: Compact Fluorescents? « Reply #8 on: July 14, 2008, 11:51:05 AM » Author: shortee
Hi that's right. That one is twice as much as the one that I saw in the store though. I think that one in the pic you showed me is the one the guy said was self ballasting. I don't think the one that I saw in the store has a ballast built in and it was 17.95 for 100 watts. I kind of want to save a lot of money by having the ballast and the ability to switch the bulbs when they get dull. Also I just don't have that much money in general. Sorry guys I just don't really know what the heck to do.
TudorWhiz
Re: Compact Fluorescents? « Reply #9 on: July 14, 2008, 12:18:43 PM » Author: TudorWhiz
No need to be sorry, its the companies who makes things too hard needs to be sorry.... :-)
Even though I'm a 1983 born....I like the olden times when life was simple....
shortee
Re: Compact Fluorescents? « Reply #10 on: July 14, 2008, 06:37:13 PM » Author: shortee
I was born the same year too. I don't get this crap. I guess I can always get a bunch of small ones instead. I hate to give up but I do. Thanks for the info. I guess it's just not making sense the way they make them anyways.
Re: Compact Fluorescents? « Reply #11 on: July 14, 2008, 07:25:03 PM » Author: icefoglights
If it's made to replace a 500 watt incandescent lamp, it would be mogul base.  All 500 watt incandescent lamps I've seen are mogul.
I do have an externally ballasted CFL that uses a medium screw base.
shortee
Re: Compact Fluorescents? « Reply #12 on: July 14, 2008, 08:13:55 PM » Author: shortee
I think it is but somebody told me that it needs a ballast made for fluorescent to work  ???  I don't know.  :P
arcblue
Re: Compact Fluorescents? « Reply #13 on: July 25, 2008, 12:31:02 AM » Author: arcblue
If you have one of those Lights of America 100w replacement CFL's with a mogul base, it probably won't work with anything except a LOA fixture due to the capacitor being located in the base of the lamp (I have read this has been tried before by running one of these on a standard electronic ballast). Bulbman and some other companies sell mogul-based CFL's that have a ballast built into the lamp base, but they are pricey.
I'm lampin...
