Author Topic: Using a 2 lamp ballast as a 1 lamp ballast  (Read 9923 times)
Foxtronix
GoL UCs4tSgJSCoCIMGThBuaePhA
Using a 2 lamp ballast as a 1 lamp ballast « on: July 09, 2008, 10:51:40 PM » Author: Foxtronix
I tested today my CGE and my Universal ballast. Both are half-dead (only one lamp starts up). So I wired a temporary fixture above my workshop with my Universal one. I plugged the first lampholder on the proper circuit (the red wires) and the second one on the yellow wires. When it starts up, this old ballast makes a soft buzzing (which I absolutely LOVE!  ;D) and it seems normal, but will the ballast overheat with this wiring configuration or will it break the lamp?
don93s
Re: Using a 2 lamp ballast as a 1 lamp ballast « Reply #1 on: July 11, 2008, 01:46:57 PM » Author: don93s
Can you be more specific....is it magnetic rapid start or electronic? Best thing is to monitor ballast and if it gets unusually hot or has bad oder or makes any other noises....discontinue immediately! If lamp seems normal brightness, and the electrode ends look normal, I guess lamp will be fine.
Foxtronix
Re: Using a 2 lamp ballast as a 1 lamp ballast « Reply #2 on: July 11, 2008, 10:05:31 PM » Author: Foxtronix
It's a magnetic rapid start ballast. And yeah all seems normal. The ballast is slightly warm after about 15 - 20 min. of operation, normal brightness and I don't really worry about the buzzing...
Mr. Big
Re: Using a 2 lamp ballast as a 1 lamp ballast « Reply #3 on: July 12, 2008, 01:50:47 AM » Author: Mr. Big
Slightly warm is fine, too hot to touch is a warning to turn it off I've had that happen to me before with a GE bonus line ballast, it got too hot to touch AND zapped me!! As a result, It got tossed across the room! It smelled bad too, what had happened was the cap went bad and leaked PCBs all over the inside of the ballast! that was a mess :-\
DimBulb
Re: Using a 2 lamp ballast as a 1 lamp ballast « Reply #4 on: July 12, 2008, 03:39:32 AM » Author: DimBulb
Just don't leave it unattended! A few years ago, I had an old GE rapid start ballast go bad in one of my garage fixtures. I left for a couple of hours and forgot to turn the lights off. When I got back, the garage was full of smoke and the ballast was leaking black PCB tar all over the floor and in my tool box! This ballast was old and didn't have a thermal switch.
My very first word was LIGHT!
TudorWhiz
Re: Using a 2 lamp ballast as a 1 lamp ballast « Reply #5 on: July 12, 2008, 10:09:29 AM » Author: TudorWhiz
Yeah Rudy, I remember pictures of your fixture that had the bad ballast with leaking tar.......I was a new member that time....:-)
Foxtronix
Re: Using a 2 lamp ballast as a 1 lamp ballast « Reply #6 on: July 12, 2008, 12:45:56 PM » Author: Foxtronix
Fortunately, my Universal ballast has a thermal switch
Mr. Big
Re: Using a 2 lamp ballast as a 1 lamp ballast « Reply #7 on: July 12, 2008, 07:12:31 PM » Author: Mr. Big
In this case, mine didn't!
GE M-400A1
My Pontiac 6000 STE
Re: Using a 2 lamp ballast as a 1 lamp ballast « Reply #8 on: July 28, 2008, 12:04:51 AM » Author: GE M-400A1
I have had a garage fire because of a old ballast that had no therm switch!
My Cars:
1986 Pontiac 6000 STE
1996 Chrysler Concorde LXi
1998 Chrysler Cirrus LXi
Foxtronix
Re: Using a 2 lamp ballast as a 1 lamp ballast « Reply #9 on: August 08, 2008, 10:11:12 PM » Author: Foxtronix
Oh...  :-\ Not cool.... Recently I leaved the ballast with 1 lamp for a while and the thermal protection blew up (I though this first). After a 1h cooling down, I see that the thermal protection is auto-reset! The good quality of the past...  :D
