Author Topic: germicidal lamp design  (Read 3445 times)
form109
germicidal lamp design « on: July 08, 2008, 11:35:54 AM » Author: form109
modern germicidal lamps resemble a compact flourescent lamp without the phosporus coating,and as such work on the same principal.
older versions of the germicidal lamp resembles an incandescent,in this lamp a tungsten filament heats some mercury vapor causing an arc to form at the tips of the lead wires,while shorting out the filament.
TudorWhiz
Re: germicidal lamp design « Reply #1 on: July 08, 2008, 03:26:05 PM » Author: TudorWhiz
actually one more thing, a germicidal lamps are made out of quartz instead of glass like CFL has glass....
The reason is because quartz does not block UV
form109
Re: germicidal lamp design « Reply #2 on: July 08, 2008, 03:27:01 PM » Author: form109
i knew that ;D
