Author Topic: convert rapidstart to preheat?  (Read 1864 times)
convert rapidstart to preheat? « on: August 02, 2017, 04:54:35 PM » Author: HomeBrewLamps
so im kindof curious, could i convert my rapid start fluoro fixture to a preheat while keeping the same ballast? (like disconnect one of the pins on each side and install a starter) this is just a question out of curiosity, no solid plan on doing this
~Owen
Re: convert rapidstart to preheat? « Reply #1 on: August 02, 2017, 06:17:36 PM » Author: Ash
Do we know what the ballast short circuit current is ?
Assuming it won't be damaged from a momentary short circuit (i dont think there is any risk, but correct me if im wrong), You can measure - connect an Ampermeter between 1 wire from each end
If the current is acceptable for the lamp cathodes - i think anything between 500..800mA would be ok.... it can be wired with a starter
Keep an eye on it for EOLs, i dont think an RS ballast would like to work in short circuit mode for any extended time though
Re: convert rapidstart to preheat? « Reply #2 on: August 03, 2017, 05:12:57 PM » Author: HomeBrewLamps
I will test it.. with my meter
~Owen
