Author Topic: LPS or HPS flashlight?  (Read 23986 times)
d3anio97
Enginerding bright things since 2011
ATL TheSOXMania
Re: LPS or HPS flashlight? « Reply #75 on: April 18, 2018, 12:35:21 AM » Author: d3anio97
You've re-rekindled my interest once more... I am curious as to what type of connector goes in that slot at the top of those ballasts... is it just an ordinary automotive connector??
yeah its an IP rated automotive connector. As for the output it's HV rated silicon cable with a split connection to handle the pulse needed to start the lamp.
What if I told you you could save 100% of your street lighting budget? Don't believe me? Buy an LED street light and run it for a week. the results will leave you in awe. (Aaaaaaand maybe wondering why you swapped that 70w SON)
Re: LPS or HPS flashlight? « Reply #76 on: April 27, 2018, 03:20:51 AM » Author: Mercurylamps
Yep those are waterproof automotive connectors. I've used them on my LED driving lights since the wiring is partially exposed.
