Author Topic: Tubular Mercury vapor lamps  (Read 2799 times)
micole66
Tubular Mercury vapor lamps « on: June 12, 2017, 02:19:41 PM » Author: micole66
There are tubular Mercury vapor lamps?
Re: Tubular Mercury vapor lamps « Reply #1 on: June 12, 2017, 03:06:27 PM » Author: dor123
There were tubular mercury lamps, but this is an obsolete type of mercury lamp. Tubular mercury lamps were mainly medium pressure mercury lamps and old high pressure mercury lamps to retrofit the medium pressure lamps:
http://www.lamptech.co.uk/MA.htm
http://www.lamptech.co.uk/MB.htm
Re: Tubular Mercury vapor lamps « Reply #2 on: June 12, 2017, 03:06:42 PM » Author: wattMaster
Tubular mercury vapor lamps do exist, but they are rare.
Lodge
Re: Tubular Mercury vapor lamps « Reply #3 on: June 12, 2017, 07:22:18 PM » Author: Lodge
What are you trying to build ? And yes there is but finding them is a challenge they haven't been made for many years.. but getting a metal halide in a tubular is easy, the light color is similar only they are more efficient, so you get more light for less watts..
Re: Tubular Mercury vapor lamps « Reply #4 on: June 13, 2017, 01:17:57 AM » Author: tolivac
Long ago--tubular mercury lamps were used in copy machines and Diazo machines.I an old projection handbook I have they descrfibe a Gamont-Kalee 35MM film projector that used a small,tubular,water cooled mercury lamp instead of carbon arc or xenon.
Re: Tubular Mercury vapor lamps « Reply #5 on: June 13, 2017, 04:39:01 AM » Author: dor123
These were special linear exposed mercury arctubes. This isn't what micole66 asked. He asked about the existance of mercury lamps with tubular outerbulbs, which are antiques, since manufacturers moved to pear, BT and elliptical outer designs, because of the use of color correcting phosphor in most of mercury lamps, and to save costs in manufacturing the clear mercury lamps without changing the design.
Lodge
Re: Tubular Mercury vapor lamps « Reply #6 on: June 13, 2017, 06:22:36 PM » Author: Lodge
And Diazo machines (blueprint printer) need a UV light source which isn't the safest of things to operate without some form of protection from the UV light, but yes those lights are fairly easy to obtain since blueprint printers are still in use..
Re: Tubular Mercury vapor lamps « Reply #7 on: June 14, 2017, 01:15:48 AM » Author: tolivac
In the US the blueprint machine is no longer in common use---Chemical costs-availability of blueprint paper.They have been replaced by digital blueprint and large format scanners-Used one at a copy place-scan your original drawing-you can even get a digital copy as well as a paper or mylar one.Other tubular mercury lamps----'How bout Cooper Hewett lamps?The predescessor to the modern flourescent lamp-have an older Electricans Handbook that describes these-they were made in AC or DC versions.In the older Diazo/blueprint machines the UV bulbs were totally enclosed-you couldn't even see them.And the cover had an interlock so the UV bulb won't come on unless the cover panel was put on the machine.
Re: Tubular Mercury vapor lamps « Reply #8 on: June 14, 2017, 05:09:27 AM » Author: dor123
Blueprint has been replaced by diazo printing and than by digital printing and digital displays. I think micole66 refered to mercury lamps with tubular outerbulbs and screwbases, which limited to medium pressure mercury lamps and their retrofit tubular high pressure mercury lamps. Mercury lamps for printing, are linear lamp and not tubular lamps.
