Author Topic: 400W Metal Halide on a Mercury Ballast  (Read 5527 times)
GE M-400A1
My Pontiac 6000 STE
400W Metal Halide on a Mercury Ballast « on: June 21, 2008, 11:14:01 AM » Author: GE M-400A1
Hi,
Could a 400W MH run on a 400W Mercury ballast. I want to know because my TB 125 has a 400W Mercury ballast and i don't have a 400W mercury bulb.
Thanks
My Cars:
1986 Pontiac 6000 STE
1996 Chrysler Concorde LXi
1998 Chrysler Cirrus LXi
gmercury2000
Re: 400W Metal Halide on a Mercury Ballast « Reply #1 on: June 21, 2008, 11:39:49 AM » Author: gmercury2000
Metal Halide lamps are not designed to run on mercury ballasts however mercury lamps can be run on standard MH ballasts. I would wait until you can get a hold of a mercury bulb before powering up you new fixture so as not to damage anything.
TudorWhiz
Re: 400W Metal Halide on a Mercury Ballast « Reply #2 on: June 21, 2008, 12:09:43 PM » Author: TudorWhiz
MH lamps will blacken much faster on MV ballasts faster due to more sputtering and have a lot shorter life too.....
GE M-400A1
My Pontiac 6000 STE
Re: 400W Metal Halide on a Mercury Ballast « Reply #3 on: June 21, 2008, 01:08:33 PM » Author: GE M-400A1
Would it be safe to run a 250 MV in my TB 125!
My Cars:
FGS
Rory Mercury!
Re: 400W Metal Halide on a Mercury Ballast « Reply #4 on: June 21, 2008, 01:29:01 PM » Author: FGS
Not recommended. It might cause the lamp to explode due to higher temp and pressure than normal. Lowes (Sylvania) or Home Depot (Philips) sells the 400w mercury vapors but they're coated.
GE M-400A1
My Pontiac 6000 STE
Re: 400W Metal Halide on a Mercury Ballast « Reply #5 on: June 21, 2008, 01:31:24 PM » Author: GE M-400A1
Home Depot does not sell 400W MV bulbs because i have looked already.
My Cars:
arcblue
Re: 400W Metal Halide on a Mercury Ballast « Reply #6 on: June 25, 2008, 01:59:00 AM » Author: arcblue
No worries, I will be sending you a 400w merc hopefully shipping it out this weekend. BTW I tried my brand new 400w Sylvania Metalarc (probe start) lamp on my 400w MV ballast and it didn't even glow. Guess it really needs the higher OCV of a metal halide ballast to even start.
I'm lampin...
GE M-400A1
My Pontiac 6000 STE
Re: 400W Metal Halide on a Mercury Ballast « Reply #7 on: June 28, 2008, 12:31:04 AM » Author: GE M-400A1
My 360W powered up on my mercury ballast just fine!
My Cars:
don93s
Re: 400W Metal Halide on a Mercury Ballast « Reply #8 on: July 04, 2008, 01:39:37 PM » Author: don93s
Sometimes MH will start on MV ballasts but usually won't. MH lamps vary in characteristics from lamp to lamp and MV ballasts vary in characteristics from ballast to ballast. The OCV in a mercury ballast can be as low as 220v and as high as 280v and the peak waveform (important to MH) can vary too. Generally, the current waveform of a mercury ballast, if it could start the MH lamp at all, would be detrimental on the electrodes and have a very short life from what I understand.
GE M-400A1
My Pontiac 6000 STE
Re: 400W Metal Halide on a Mercury Ballast « Reply #9 on: July 20, 2008, 02:10:26 AM » Author: GE M-400A1
Thanks Don!!
My Cars:
