Author Topic: Highest wattage T8 lamps widely used in the US  (Read 2587 times)
Highest wattage T8 lamps widely used in the US « on: April 13, 2017, 03:29:15 PM » Author: Ash
What are the highest wattage T8 lamps that are commonly used in the US ?
Special interest is in 8ft lamps, preferrably with 2 pin bases (that can be preheated)
Re: Highest wattage T8 lamps widely used in the US « Reply #1 on: April 13, 2017, 09:25:16 PM » Author: xmaslightguy
Highest I know of is the F96T8 HO - 86w
I guess in theory it could be pre-heated if the proper ballast existed...
Re: Highest wattage T8 lamps widely used in the US « Reply #2 on: April 14, 2017, 02:12:56 AM » Author: Ash
Is it in common use or just "lamp exists" ?
By preheated i dont mean specifically preheat ballast, but anything that heats the cathodes including Programmed Start / Rapid Start (do Magnetic RS exist for this lamp ?)
Is it exact same length as F96T12 ?
What happened to F96T12 HO in the colors 830/841 ?
Re: Highest wattage T8 lamps widely used in the US « Reply #3 on: April 14, 2017, 06:28:16 PM » Author: xmaslightguy
Is it in common use or just "lamp exists" ? They aren't real common, but are a standard lamp, and are still made. Never seen one for sale in a store, but they are easily available online.
I do have a pic of one here
By preheated i dont mean specifically preheat ballast, but anything that heats the cathodes including Programmed Start / Rapid Start (do Magnetic RS exist for this lamp ?)  The ballasts I've seen are electronic Rapid Start or Programmed Start. Not sure if a magnetic RS ballast ever existed for them, or for that matter if they even existed before the magnetic ballast bans.
Is it exact same length as F96T12 ?  Yep they are, and have the same RDC endcaps as a HO T12
What happened to F96T12 HO in the colors 830/841 ?  both are still available, as is 850 & 865...
Re: Highest wattage T8 lamps widely used in the US « Reply #4 on: April 15, 2017, 03:40:54 AM » Author: Ash
What you mean by still available ? Is it expected to go down soon ?
With the F96T12, there is this older catalog page :
http://www.randrsupply.com/Customer/rrsupp/specpages/PHILTGE00542_80.pdf
Most Halophosphor lamps are getting dropped, Triphosphors presented or new introduced
Current Philips website :
http://www.usa.lighting.philips.com/prof/conventional-lamps/fluorescent-lamps-and-starters/tl/high-output-t12/productsinfamily
http://www.lighting.philips.com/main/prof/conventional-lamps/fluorescent-lamps-and-starters/tl/high-output-t12/productsinfamily
Only Halophosphor remain ? (with the exception of one lamp the TLRS in the 2nd link, and only in 841)
Not clear to me what they are doing there ? I'd expect Halophosphor lamps to go and Triphosphor to stay ?
BlueHalide
Re: Highest wattage T8 lamps widely used in the US « Reply #5 on: April 15, 2017, 12:57:08 PM » Author: BlueHalide
xmaslightguy is exactly right, T8HO came about just 10 years ago as an efficient alternative to T12HO, there were never any magnetic ballasts for them as the format didnt exist more than a decade ago.
The F96T8HO is rated at 86w
One exception is GE made a F96T8HO lamp for a short while that was rated at 96w and was a retrofit lamp for F96T12HO ballasts, I remember installing a few years ago, they were only available in 4100K as far as I know. So technically this would be the highest wattage T8, however I havent seen these in years, who knows if theyre still made.
Re: Highest wattage T8 lamps widely used in the US « Reply #6 on: April 15, 2017, 04:41:35 PM » Author: Ash
Is the F96T8 HO a good default 8ft lamp for new installations ?
BlueHalide
Re: Highest wattage T8 lamps widely used in the US « Reply #7 on: April 15, 2017, 09:09:12 PM » Author: BlueHalide
It is a good default lamp for applications that would normally use F96T12HO, the light output is basically the same but with lower wattage. A standard F96T8 is rated at 59w and is the normal output version which is much more widely used in 8' striplight installations. These however are all single pin (slimline) instant start
Re: Highest wattage T8 lamps widely used in the US « Reply #8 on: April 15, 2017, 10:23:49 PM » Author: xmaslightguy
Quote from: Ash
I simply mean they can still fairly easily be found (in this case its online only .. I've only ever seen the 4100k F96T12 HO's in stores, and they do still have them)
Quote
Don't really know what they're doing for sure, and I could only see the 1st one of your 3 links (others showed a Philips page, but no lamp info..likely had something considered unsafe/or advertising related so my computer blocked that section)
But probably what you are seeing is lamps made to fit around the bans. Did they by chance say something like "Low Temperature?" or "Cold Temperature?" If so, then its exempt from the current lamp bans. :)
Re: Highest wattage T8 lamps widely used in the US « Reply #9 on: April 15, 2017, 10:29:25 PM » Author: xmaslightguy
Quote from: BlueHalide
:o I never have seen, or even knew such existed :o
I deff need to find some of those and test one on my Thorn 8' switch start ballast 8)
BlueHalide
Re: Highest wattage T8 lamps widely used in the US « Reply #10 on: April 16, 2017, 12:56:26 AM » Author: BlueHalide
@xmaslightguy, they mustve been a very short production run as a google search/GElighting.com yields nothing. This wouldve been 2010-ish when I installed them last. I remember they were a sale item at the HEIN Electric supply shop I used, and had actually went there that day to pick up a case of F96T12HO for a relamping job, the sales counter guy recommended the GE 96w T8's
