Author Topic: My Osram HQI-TS 70W/WDL Excellence, vibrates in brightness despite it is new  (Read 2076 times)
My Osram HQI-TS 70W/WDL Excellence, vibrates in brightness despite it is new « on: April 13, 2017, 02:40:45 PM » Author: dor123
I noticed right now, that my Osram HQI-TS 70W/WDL Excellence in my tracklight, strongly vibrates in brightness, and behaves like it is about to cycle, despite it is brand new (The arctube is clear).
Why?
Re: My Osram HQI-TS 70W/WDL Excellence, vibrates in brightness despite it is new « Reply #1 on: April 13, 2017, 02:47:15 PM » Author: Ash
Arc root spot is not stable or the ignitor fires up. Try to turn the lamp upside down (spin it around its axis, not swap the ends) or replace the ignitor and see what happens
Re: My Osram HQI-TS 70W/WDL Excellence, vibrates in brightness despite it is new « Reply #2 on: April 13, 2017, 03:06:51 PM » Author: dor123
My tracklight have an electronic HID ballast. These aren't looks like the ones that caused by the ignition circuit inside the ballast firing, but just randon vibrations.
I can't turn the lamp upside down when it is operating. The tracklight can be adjusted only at 90deg from high to low.
Video will follow.
Re: My Osram HQI-TS 70W/WDL Excellence, vibrates in brightness despite it is new « Reply #3 on: April 13, 2017, 03:09:41 PM » Author: Ash
Take out the lamp and put it in upside down
Re: My Osram HQI-TS 70W/WDL Excellence, vibrates in brightness despite it is new « Reply #4 on: April 13, 2017, 03:21:52 PM » Author: dor123
I needs to do this, when the lamp is cold, and for this, I need to turn it off and wait 4 mins before I can turn it around.
I doing this often, before turning it on, in order to accelerate its run-up from 2 mins to 1 min.
Its sometimes doing this, but not always. I think it doing this, if it operates for long times of several hours.
Re: My Osram HQI-TS 70W/WDL Excellence, vibrates in brightness despite it is new « Reply #5 on: April 13, 2017, 04:17:55 PM » Author: James
The Osram HQI-TS is sensitive to acoustic resonances, which can be caused by certain kinds of electronic ballast depending on the frequency.  Maybe that is what you are seeing.  In such cases the arc itself is not stable and can swirl around inside the arc tube appaerently randomly, which gives a flickering effect.  The lamp life is usually not good when this happens, or can even be destroyed.
Re: My Osram HQI-TS 70W/WDL Excellence, vibrates in brightness despite it is new « Reply #6 on: April 14, 2017, 03:01:00 AM » Author: dor123
The ballast used, is a Philips HID-PrimaVision PV C 70 /S CDM, operating at 140hz square wave current.
Anyway, here is the video .
