Author Topic: F96/F72T12/HO overdrive  (Read 3545 times)
RyanKorponay12
Ryan Korponay The Ballaster
F96/F72T12/HO overdrive « on: April 06, 2017, 02:24:57 PM » Author: RyanKorponay12
Will a F96/F72T12/HO ballast overdrive a f48T12/HO to much or would this be okay?
« Last Edit: April 06, 2017, 11:12:38 PM by RyanKorponay12 » Logged
The Ballaster!!! *Poof*...
Re: F96/F72T12/HO overdrive « Reply #1 on: April 06, 2017, 02:36:07 PM » Author: Ash
Very likely to overheat the ballast if it is a magnetic ballast
RyanKorponay12
Re: F96/F72T12/HO overdrive « Reply #2 on: April 06, 2017, 11:12:44 PM » Author: RyanKorponay12
alright
suzukir122
suzukir123
Re: F96/F72T12/HO overdrive « Reply #3 on: April 08, 2017, 12:31:30 AM » Author: suzukir122
Yep it could over heat the ballast. This also is the case with Normal Output rapid
start as well I'm pretty sure.
Interests:
Re: F96/F72T12/HO overdrive « Reply #4 on: April 14, 2017, 09:25:57 AM » Author: funkybulb
Some magnetic ballast will go that low that is listed
Only problem is shorter lamps is harder on ballast
Your better off getting F48T12HO ballast
Those are F24 to F48T12HO
