April 23, 2025, 08:30:41 PM
General
General Discussion
Receptacle Replacement
Topic: Receptacle Replacement (Read 2908 times)
« on: January 17, 2017, 10:54:24 AM »
I recently bought a streetlight, and it works normally. However, the PC receptacle is getting scrached by the PCs. How can I replace the PC receptacle/socket?
SLS!
(Stop LED Streetlights!)
Re: Receptacle Replacement
« Reply #1 on: January 17, 2017, 03:29:03 PM »
Are they significant scratches ? Minor surface scratches won't affect it. Maybe you have one photocell with bent pin or the like which is causing all the trouble
Anyway it would probably be held in place by screws from the top or a big nut from the bottom. If it is old its possible that the gasket stuck to the Plastic and appears to hold it
« Reply #2 on: January 17, 2017, 03:33:33 PM »
It's held in by some metal spring ring.
SLS!
« Reply #3 on: January 17, 2017, 03:51:35 PM »
Like a big E-clip ?
« Reply #4 on: January 18, 2017, 04:07:19 PM »
It looked like a modified e-clip.
SLS!
« Reply #5 on: June 17, 2017, 08:49:05 AM »
Any answers? Also, the PC socket doesn't seem to have any screws, so I would have to somehow extract the clip thing.
SLS!
« Reply #6 on: June 17, 2017, 08:59:11 AM »
Do you have a photo of how its attached?
« Reply #7 on: June 17, 2017, 09:05:07 AM »
You can kind of see how it's mounted in
this
photo.
SLS!
Beta 5
« Reply #8 on: June 17, 2017, 10:42:22 AM »
Beta 5
Can you show us a picture of the scratches?
Fluorescent Forever
Lodge
« Reply #9 on: June 17, 2017, 01:42:48 PM »
Lodge
It looks like you have to just pry the three tabs against the socket and then pull it straight out, they don't have to move far just past the lip on the socket, and then push the new one back in, there should be a lip on the socket those tabs push against.. But have you tried to just polish the socket with an old piece of denim or heavy cotton to take the scratches out or at least make them less noticeable...
