Author Topic: What did you do today lighting wise?  (Read 434609 times)
Re: What did you do today lighting wise? « Reply #15 on: September 30, 2016, 06:58:40 PM » Author: RyanF40T12
Today I partially melted the head of my favorite Philips screw driver when I foolishly used it to try to push some wires further back in a wall box.  Quite a brief light show!  And it didn't trip the breaker either :D
Re: What did you do today lighting wise? « Reply #16 on: September 30, 2016, 07:23:36 PM » Author: Ash
By flicker i mean the 120Hz of any lamp on Magnetic ballast, or 60Hz (annoying when it happens in indoors highbay over your head !) when a MH starts to rectify
Re: What did you do today lighting wise? « Reply #17 on: September 30, 2016, 10:34:09 PM » Author: wattMaster
Today, I printed some of my lighting photos to have physical copies of.
Re: What did you do today lighting wise? « Reply #18 on: November 25, 2016, 01:22:16 AM » Author: RyanF40T12
Last night and much of today I worked in 1 of 17 buildings, pulling out Sylvania F32T8 4100ks and replacing them with 5-8 year old vintage Sylvania F32T8 3000k.  I need the 4100ks for a building that doesn't reflect well with the 3000k.  Also I want to use up these 5-10 year old 3000ks.  I also converted about 10 fixtures from being on 24/7 to switch operation.  This building only needs 5 on 24/7 fixtures, not 20.  Not sure what the boneheads were smoking when they built the building.
Re: What did you do today lighting wise? « Reply #19 on: November 25, 2016, 07:21:29 PM » Author: AngryHorse
This morning, (in the frost)!, I fitted two 150watt TD halide floods above our vehicle jet washing station at work, then split a load of 400watt halide floods into two circuits, (from one), that had been pulled up on an electrical inspection!
Fitting a lighting column and feeder pillar next week for some more halide floods on our new compound.
Current: UK 230V, 50Hz
Power provider: e.on energy
Re: What did you do today lighting wise? « Reply #20 on: November 26, 2016, 01:25:11 AM » Author: RyanF40T12
Today I finished the rest of the building converting over to 3000K from 4100K.  Well all that I wanted to get done. Now I have a bunch of 4100K tubes that have used up between 1/2 and 3/4 of their life :)  I'll stage them down at buildings closer to me so that I can run them to EoL and change em out myself.
hannahs lights
Re: What did you do today lighting wise? « Reply #21 on: December 05, 2016, 08:36:33 AM » Author: hannahs lights
Just yesterday I was at my sisters house and she was saying most of her Xmas lights didn't work so I sat there for an hour repairing them it was mostly changing out blown bulbs and checking plug wiring. I felt I've done a good thing for her
Re: What did you do today lighting wise? « Reply #22 on: January 28, 2017, 02:20:57 AM » Author: RyanF40T12
Replaced 4 dead T8 ballasts today in 2 church buildings, as well as a few EOL lamps.
Re: What did you do today lighting wise? « Reply #23 on: January 31, 2017, 02:25:18 AM » Author: RyanF40T12
Parking lot light light duty tonight for a few poles at one of the church buildings.  25 feet up in the air on an A-Frame ladder, struggling to unscrew the bulb out of the socket, and it won't budge.  Was afraid the bulb would shatter in my hands (had gloves on) but the cement gave out instead.  The screw base is stuck/welded into the socket.  Going to have to get a new socket.  GRRRRRRR.
150 Watt HPS Large base.
« Last Edit: January 31, 2017, 02:27:26 AM by RyanF40T12 » Logged
Re: What did you do today lighting wise? « Reply #24 on: January 31, 2017, 02:30:41 AM » Author: RyanF40T12
On a side note- One of the parking lot bulbs I removed today at that same building was a 1998 vintage GE Lucalux (Say luca luca luca 10 times very fast) so it was likely put in the same time these fixtures were put in, back in 98.  The bulb was still burning, but rather dim.  Not too shabby.
Re: What did you do today lighting wise? « Reply #25 on: February 07, 2017, 01:32:07 AM » Author: RyanF40T12
Today I replaced 3 crappy Universal Triad T8 ballasts that lasted maybe.. 10-12 years of very limited use, before they crapped out.  What a shame.  Before T8s came along, Universal made the best ballasts out there.  Electronic ballasts SUCK.
Re: What did you do today lighting wise? « Reply #26 on: February 07, 2017, 01:58:00 AM » Author: Ash
Id like to see what failed inside
Re: What did you do today lighting wise? « Reply #27 on: February 10, 2017, 10:15:51 PM » Author: RyanF40T12
Today I gutted a 2003 era 175 Watt MH RAB Wall Pack and "upgraded" it to 150 Watt HPS.  New photocell as well.
Re: What did you do today lighting wise? « Reply #28 on: February 11, 2017, 01:12:55 AM » Author: tolivac
I bought two Hi-Bay four bulb Metalux F54T5 lights from Lowes-Hooked them up-one of the few flourescent lights i like.Lowes display touted them as replacing 400W MH-Ran one of those lights next to a 400W MH light-and I don't think so-the MH wins!!!But like the new flourescent light anyway.Also bought 4 Sylvania LED lamps to replace some CFL bulbs in the bathroom!The 100W eq bulbs are MUCH better-will see how they do.So my last weekend did get some new lighting equipment.Got to feed my flashoholic needs!
Re: What did you do today lighting wise? « Reply #29 on: February 14, 2017, 09:33:06 PM » Author: RyanF40T12
Today I went to our most remote church building to fix some minor things.  I also replaced an EoL cycling 100W HPS bulb in a wall pack, and also replaced about 5 EoL F32T12s with new ones.  Sylvania 4100k, Ecologic 3.  They are good tubes with a very nice white tone.  No dim starting unlike the Previous Gen Ecologic II- which were very poor and gave Sylvania fluorescents a bad rap from 2004ish until the Eco-3s came out in 2014/15.  The Eco-1s had no issues and were very reliable, I predict the Eco 3's will be just as good.  The Eco-3s also have filament guards too, something they had not had previously.
