Author Topic: What did you do today lighting wise?  (Read 333511 times)
desktoptrashcan
theroadrunner556
Re: What did you do today lighting wise? « Reply #720 on: December 04, 2020, 06:55:34 PM » Author: desktoptrashcan
My 100W MV fixture arrived today.  :mv:
Wireman
Re: What did you do today lighting wise? « Reply #721 on: December 04, 2020, 06:59:47 PM » Author: Wireman
Yeah! Might have been my wirenut comment that garnered her to give me a slap that then combined with the Led Lights made her go ever the edge! ;D ;D :mrg: :slap:
I saw that one earlier today. She sent you to the moon my friend! BANG! ZOOM!
Bulbman256
Mad Max
Bulbman256
Re: What did you do today lighting wise? « Reply #722 on: December 04, 2020, 06:59:55 PM » Author: Bulbman256
I love it, especially the bubble lights!
Thanks, Going to get a few more of them later on today or tomorrow to put on because i love them and the spare lamps i have found are 3 dollars for 2. :)
Re: What did you do today lighting wise? « Reply #723 on: December 04, 2020, 07:01:20 PM » Author: sox35
I have to get a couple, where did you find them?
Re: What did you do today lighting wise? « Reply #724 on: December 05, 2020, 06:30:23 AM » Author: sox35
Ah, but you know we love you really  :-* :love:
Bulbman256
Mad Max
Bulbman256
Re: What did you do today lighting wise? « Reply #725 on: December 05, 2020, 10:19:46 AM » Author: Bulbman256
I have gotten mine from hobby lobby they have some neat lighting stuff there. The lamps are only as replacements not a full set so i would get them when the prices really drop off. Will check sales today.
Bulbman256
Mad Max
Bulbman256
Re: What did you do today lighting wise? « Reply #726 on: December 05, 2020, 10:23:08 AM » Author: Bulbman256
She sure Did! :slap: :o
Aww your making me blush.  :-[ ::) :love:
Re: What did you do today lighting wise? « Reply #727 on: December 05, 2020, 07:13:51 PM » Author: WorldwideHIDCollectorUSA
I received a clamp on amp meter and gathered the following data for lamp currents on different ballasts. Here are the results from testing different HID lamp/ballast combinations:
US 35w S76 HPS lamp on 2 F20T12 chokes wired in parallel using 2 wire HPS ignitor:
Ran at about 0.85a.
US 35w S76 HPS lamp on a F20T12 choke and a 13w PL choke wired in parallel using 2 wire HPS ignitor:
Ran at about 0.35a.
US 100w H38 MV lamp on proper HX ballast:
Ran at about 0.875a
European spec 80w MV lamp on H38 HX ballast:
Ran at about 0.944a.
European 70w internal ignitor HPS lamp on H38 HX ballast:
Ran at about 1.0a.
35w SOX lamp on US 35w M130 MH ballast using European 35w 2 wire SOX ignitor:
Fluctuated widely between 0.44a and 0.78a. I sometimes have gotten readings close to 0.56a and 0.63a.
US 70w M143 CMH lamp on H38 HX ballast using 2 wire HPS ignitor:
Ran at about 1.0a.
European 70w SON-T HPS lamp on H38 HX ballast using 2 wire HPS ignitor:
Ran at 1.127a.
US 70w M98 MH lamp on H38 HX ballast using 2 wire HPS ignitor:
Ran at 1.196a.
US 70w M143 CMH lamp on 70w M98 MH ballast in E-conolight wall pack:
Ran at 0.783a.
European 70w SON-T HPS lamp on 70w M98 MH ballast in E-conolight wall pack:
Ran at 1.0a.
US 70w M98 MH lamp on proper ballast in E-conolight wall pack:
Ran at 0.883a.
European 70w internal ignitor HPS lamp on 70w M98 MH ballast in E-conolight wall pack without ignitor:
Ran at 0.90a.
US 100w H38 MV lamp on 70w M98 MH ballast in E-conolight wall pack without ignitor:
Ran at 0.694a.
European spec 80w MV lamp on 70w M98 MH ballast in E-conolight wall pack without ignitor:
Ran at 0.761a.
Re: What did you do today lighting wise? « Reply #728 on: December 06, 2020, 12:11:17 AM » Author: RyanF40T12
Changed out two EoL 35W HPS bulbs, one likely lasted 20 years.. very impressed.   Also changed out two F32T8 5000K EoL tubes that were on a programmed start ballast.  The programmed start ballast likely killed the 2nd tube when the 1st one went EoL as it cycled both tubes on and off when the first tube went EoL.  Disadvantage of Programmed start.  Can be very annoying in certain situations with the flickering of it going on and off so much.
WigWag
Re: What did you do today lighting wise? « Reply #729 on: December 06, 2020, 10:10:32 PM » Author: WigWag
There's a Hobby Lobby near me so I might have to have a look see myself. Thanks!
Bulbman256
Mad Max
Bulbman256
Re: What did you do today lighting wise? « Reply #730 on: December 06, 2020, 11:23:18 PM » Author: Bulbman256
Was gonna check today but they are closed on Sundays. :-[ Well there is always tomorrow, need to get a few more anyway!  ;D
Re: What did you do today lighting wise? « Reply #731 on: December 06, 2020, 11:33:45 PM » Author: Mandolin Girl
Yeah I looked them up online and closed! Argh! Gotta wait til tomorrow!
Re: What did you do today lighting wise? « Reply #732 on: December 09, 2020, 11:10:28 AM » Author: Mandolin Girl
We got a package from the States today with 2 clear MV lamps in it. A 100W one, and a 400W one.  :mv: :mv:
The 100W one is litted at the moment, running off the correct ballast that's plugged into our inverter.! :mv: :mv: 8)
Re: What did you do today lighting wise? « Reply #733 on: December 10, 2020, 12:47:42 PM » Author: Mandolin Girl
Today it's the 400W MV lamp being litted.  :mv: 8)
Nice and bright, and warm as well.  :D :mv:
High Intensity
Re: What did you do today lighting wise? « Reply #734 on: December 11, 2020, 04:05:03 AM » Author: High Intensity
Just got done retrofitting two dead 2xF96T12 striplights to 4xF40T12.
