Author Topic: What did you do today lighting wise?  (Read 330308 times)
Bulbman256
Mad Max
Bulbman256
Re: What did you do today lighting wise? « Reply #690 on: November 27, 2020, 06:06:59 PM » Author: Bulbman256
Where can you get bubbler tubes?
I bought them at hobby lobby, Seems to be the only place that sells them i found and only as replacement lamps.
mdcastle
mdcastle 26956281@N02
Re: What did you do today lighting wise? « Reply #691 on: November 27, 2020, 07:34:58 PM » Author: mdcastle
Went to see the fluorescent street lights in Appleton, MN. Gone, replaced by LEDs.
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: What did you do today lighting wise? « Reply #692 on: November 27, 2020, 08:26:18 PM » Author: Binarix128
I made some homemade indicators from recycled materials.
Re: What did you do today lighting wise? « Reply #693 on: November 27, 2020, 08:44:52 PM » Author: WorldwideHIDCollectorUSA
Seems to be that all of these rare lanterns are facing extinction due to LED.
Wireman
Re: What did you do today lighting wise? « Reply #694 on: November 28, 2020, 01:16:50 PM » Author: Wireman
True they are but how is this related to doing anything lighting wise today?
Re: What did you do today lighting wise? « Reply #695 on: November 28, 2020, 01:42:42 PM » Author: WorldwideHIDCollectorUSA
Personally this is a response to someone witnessing the replacement of rare street lanterns.
Bulbman256
Mad Max
Bulbman256
Re: What did you do today lighting wise? « Reply #696 on: November 28, 2020, 04:15:44 PM » Author: Bulbman256
I got my 25w Phillips self ballasted cmh lamp and set up a strand of misalaious candelabra lamps including a few bubbler tubes i bought yesterday.
Fluorescent05
Zack
Re: What did you do today lighting wise? « Reply #697 on: November 28, 2020, 05:58:16 PM » Author: Fluorescent05
I set up my Christmas lights in my front yard today.
HPS_250
Long live the HPS and SOX!
UCAjfrNb4v77ybEBBYqxZxiw
Re: What did you do today lighting wise? « Reply #698 on: November 28, 2020, 06:12:37 PM » Author: HPS_250
Cool! I set up some Christmas lights yesterday outside, more to come. All incandescent still.  :)
Fluorescent05
Zack
Re: What did you do today lighting wise? « Reply #699 on: November 28, 2020, 11:38:20 PM » Author: Fluorescent05
Nice! The ones I did today are a mixture of incandescent and LED because my dad refuses to buy new incandescent sets.
HPS_250
Re: What did you do today lighting wise? « Reply #700 on: November 29, 2020, 12:07:19 AM » Author: HPS_250
My dad refuses to buy new LED sets.  ;D
He actually told me an $85 electric bill is “worth it” for “real” Christmas lights, and not LED junk, which I completely agree with that.  ;D
Re: What did you do today lighting wise? « Reply #701 on: November 29, 2020, 12:19:51 AM » Author: xmaslightguy
Put up the last 10 sets of Christmas lights outside. (some LED, some incandescent).
Fixed a few sets outside that weren't working.
Put up a few small trees inside (all LED lights used).
Re: What did you do today lighting wise? « Reply #702 on: November 29, 2020, 07:21:33 PM » Author: RyanF40T12
Been busy fixing a bunch of T8 ballasts that were installed incorrectly.  These are programmed start ballasts that replaced rapid start T12.  In order for the programmed start ballasts to heat the filaments/cathodes properly or even at all, the the wires have to be run to the sockets individually and not doubled up.  I am also replacing some of these .41 amp ballasts with .50+ amp ballasts as these are in recessed fixtures and need more light output.  The original T-12 ballasts were .78 amp I believe so decent light output on T12 but with T8 .40 or .41 amp doesn't quite cut it for higher up fixtures.
Re: What did you do today lighting wise? « Reply #703 on: December 01, 2020, 04:04:39 PM » Author: RyanF40T12
More fun at the church building fixing some of the improperly installed programmed start ballasts.
Had some fun with an EOL Sylvania F32T8 3000K.  It was in one of the instant start ballast driven fixtures, so it didn't die out completely until I put it on an instant start ballast.  In the photos you can see that both ends had the black socks.  It took about 10 min of it running before it lost vacuum.  Both ends were doing the red spiral death dance.  One side started to return from pink to the warm white color too.  Lots of fun :)
Cursed out 2 newer Philips F32T8 3500k tubes where the weak cathodes broke away when I installed the lamps into the fixture.  Grrrrrrrrr. Been an issue with Philips since the 700 series dating back to the late 90s. Some did this new out of the box, most do it when you remove them after they have run for a short time or long time and install them in a new fixture.  The slight jarring of removing the tube is
enough to break off the weak cathodes.
Re: What did you do today lighting wise? « Reply #704 on: December 01, 2020, 04:55:50 PM » Author: Mandolin Girl
We lit our glorious SOI/H lamp.  :lps: :lps:
It's nearly 60 years old and today was its first time of lighting :love:
