Author Topic: What did you do today lighting wise?  (Read 330304 times)
Re: What did you do today lighting wise? « Reply #675 on: November 18, 2020, 08:52:52 AM » Author: sox35
I just got a GE constant color CMH self ballasted PAR38 lamp today and spent the evening figuring out where to use it.
For now it's in one of my track lights highlighting some glass collectibles.
I like the color of the light but it's not so good on red objects.
For $13 though I couldn't pass it up especially since I've seen several members on here buy them.
We have a couple of the Philips 240V version of these, which are 25W rather than the rather strange 23W. The colour is very similar to incandescent, which is probably why we like them :par:
« Last Edit: November 18, 2020, 08:54:46 AM by sox35 » Logged
Binarix128
220V AC 50Hz, NTSC
GoL UCOUT2noI2R__jgPSJUjGRtA
Re: What did you do today lighting wise? « Reply #676 on: November 18, 2020, 08:56:32 AM » Author: Binarix128
I changed the bulbs in the bathroom back to incandescent after a week or so experiment with GE Relax filament LED A19s.
Nice! I would experiment with cold light incandescents and fluorescent tubes for bathroom lighting.
Wireman
Re: What did you do today lighting wise? « Reply #677 on: November 18, 2020, 10:04:05 AM » Author: Wireman
Not sure how to describe the color from the GE that I have. It's slightly warm like incandescent but it's still seems like a cooler white light and as I mentioned red objects don't look to good under it. The listed color temp is 3000K with a CRI of 81.
Fluorescent05
Zack
Re: What did you do today lighting wise? « Reply #678 on: November 18, 2020, 10:13:36 AM » Author: Fluorescent05
Mine is slightly pinkish.
Re: What did you do today lighting wise? « Reply #679 on: November 18, 2020, 10:20:42 AM » Author: Mandolin Girl
I guess the best way to describe mine is something like pale incandescent and white light like halogen.
Re: What did you do today lighting wise? « Reply #680 on: November 18, 2020, 01:57:19 PM » Author: Mandolin Girl
Have a look at the last uploads section of the gallery, we've been busy with the camera and there are a few more pictures there.  :bulbman:
Binarix128
220V AC 50Hz, NTSC
Re: What did you do today lighting wise? « Reply #681 on: November 20, 2020, 12:50:38 PM » Author: Binarix128
I bought red incandescent xmas lights for decorate our xmas tree.
Re: What did you do today lighting wise? « Reply #682 on: November 24, 2020, 02:36:02 PM » Author: Mandolin Girl
I did this yesterday actually:
I played a game of lamp box Tetris to get them all fitted into our lampses cupboard.!  :lol:
HPS_250
Long live the HPS and SOX!
UCAjfrNb4v77ybEBBYqxZxiw
Re: What did you do today lighting wise? « Reply #683 on: November 26, 2020, 11:06:16 AM » Author: HPS_250
Decorated the front of my house with incandescent Christmas lights.
I also organized some 100w MV lamps.
Re: What did you do today lighting wise? « Reply #684 on: November 26, 2020, 11:45:32 AM » Author: xmaslightguy
A few days ago..
Put up Christmas lights outside.
Put up a magenta-colored tree inside, and used pink LED lights in it.
Yesterday..
Wasted probably a couple hours trying to get a controller for the outside Christmas lights working right... turns out I had a cat-5 cable with a bad end on it.
Put up some more lights outside(mostly done now)
Put up another tree inside, in this case a white tree (lights I used were home-done LED twinkle green). Plan to do another white tree (probably today) with the same type of lights but blue.
There's a set of lights I need to fix outside, but the roof is covered with snow/ice...and 3 stories up is a long way down... :o
(might just have to get the hose up there & use it to melt the snow/ice in that little section I need to get to) .LOL.
Re: What did you do today lighting wise? « Reply #685 on: November 26, 2020, 08:43:00 PM » Author: joseph_125
I fixed some loose screw bases on a couple of HID lamps I have. One a Philips 175w R40 mercury, the other a no name 70w HPS.
In case you were wonder how I fix them, you have to desolder the leads from the base, apply a suitable adhesive (I usually use Gorilla Glue), use tape or some means to clamp the base to the bulb for around 2 hours. Finally you solder the leads back to the base.
For good measure I'll let the lamp run up after I'm done for about an hour to test the repair job.
Re: What did you do today lighting wise? « Reply #686 on: November 27, 2020, 07:57:04 AM » Author: Mandolin Girl
We use Gorilla Glue as well.  :)
It has the added bonus that it cures with the application of heat.  8)
Re: What did you do today lighting wise? « Reply #687 on: November 27, 2020, 04:18:17 PM » Author: RyanF40T12
yesterday I spent a few hours increasing the T8 brightness in some areas of a church building by pulling out the .40 amp ballasts and bumping them up to .50 and .80 and replaced the 3000k tubes in those fixtures with 4100K tubes.  Going to have some more fun at that building tomorrow and maybe tonight.  That building has blue and white accents so it favors the 4100k much better vs the 3000k.  Most of the 3000k tubes are still in good shape because they were using programmed start ballasts, so I'll take those tubes over to other buildings where they have 4100k which favors 3000k due to the accents, and swap out :)  I'm bored, what can I say :)
Bulbman256
Mad Max
Bulbman256
Re: What did you do today lighting wise? « Reply #688 on: November 27, 2020, 04:27:36 PM » Author: Bulbman256
Mailed a few lamps to hpsmvf for a trade, Bought some black Friday holiday lighting inducing some bubbler tubes, and set up my dollar tree in my room.
Re: What did you do today lighting wise? « Reply #689 on: November 27, 2020, 05:00:13 PM » Author: Lumex120
Where can you get bubbler tubes?
Unofficial LG Discord
