Author Topic: What did you do today lighting wise?  (Read 333837 times)
Re: What did you do today lighting wise? « Reply #525 on: May 17, 2020, 10:33:02 AM » Author: sox35
Run the lamp off 2 50W chokes in parallel then I and V will be spot on.
50W MV or 50W HPS..? In any case I'd have to get some, don't have any 50W ballasts of any type spare  :-\
LightsDelight
Fred Dirst is watching you
Re: What did you do today lighting wise? « Reply #526 on: May 17, 2020, 10:34:04 AM » Author: LightsDelight
MV :mv:
Keep discharge lighting alive
Re: What did you do today lighting wise? « Reply #527 on: May 17, 2020, 10:34:52 AM » Author: sox35
Ok, I'll give that a try once I can get a couple of ballasts.
Re: What did you do today lighting wise? « Reply #528 on: May 17, 2020, 03:42:04 PM » Author: xmaslightguy
It was a plumbing-related project, but doing it required getting into lights....
Yesterday I replaced a shut-off valve in the basement (opposite side of the room shown in this pic . Doing so required un-installing one of the lights & taking a couple others apart. (the reason the lights are where they are in that room is because pipes run along the same space, so it works out well).
The valve part was all done yesterday (a simple project really). But I left the lights overnight, then put everything back today.
SodiumCapital
HID FTW
UCfbWteal5F__jqxRlWqJ96g
Re: What did you do today lighting wise? « Reply #529 on: May 22, 2020, 05:10:30 PM » Author: SodiumCapital
Today at my Home Depot where I work, I relamped a 4 ft T12 fixture on display and removed some dead T8s from a troffer display to prep them for relamping as well when we settle on how to get new tubes. We are gonna have to use product T12s and T8s from off the shelf since we don't have any spares put away for displays. These displays never really get serviced anymore. Another 3 fixtures do not have lamps in them and require them according to the bay's design. Including one 8 foot T12 strip light! I also bought a clearance value pack of 7W night light bulbs for a dollar and 3 cents for the house. And finally, relamped my brother's ceiling fan cause the LED lamp in it died a couple of days ago. I replaced it with a CREE 4000K lamp. The old lamp was a EcoTech 3000K that came with the ceiling fan. Lasted about a year and a half. The room looks better in 4000K light anyway!
Once we actually get to relamping the fixtures at work, I'll take before and after photos. Who knows when we can focus on it though. We have much bigger fish to fry atm.
Re: What did you do today lighting wise? « Reply #530 on: May 23, 2020, 08:06:45 PM » Author: sox35
Rewired my display board for 90W SOX lamps  :lps:
fluorescent lover 40
Re: What did you do today lighting wise? « Reply #531 on: May 23, 2020, 08:24:02 PM » Author: fluorescent lover 40
I lit up one of my Philips-Westinghouse 70w HPS BT-25s. Not as much blue in the start-up as I had hoped but still cool.
High Intensity
Re: What did you do today lighting wise? « Reply #532 on: May 23, 2020, 10:52:15 PM » Author: High Intensity
Relamped a slimline fixture in my parent's garage that has been dead for as long as i can remember. It had a dead GE bulb from September of either '88 or '98, and a dead Philips bulb from January of '89. They moved in in 2000 so i'm willing to bet the fixture has never been relamped during our time here.
Re: What did you do today lighting wise? « Reply #533 on: June 07, 2020, 02:46:22 PM » Author: sox35
Rewired a display board for SO/H and SOI/H lamps using a Philips L4045 leak transformer ballast. This ballast is quite versatile as it will run pretty much anything that requires 0.6A, so that includes 35W & 55W SOX, also 36W SOX-E as well as the older 45W/60W/85W SO/H and SOI/H lamps. Photos later  :lps:
08/06/20 - Here is the finished board 8) :lps:
« Last Edit: June 08, 2020, 12:55:43 PM by sox35 » Logged
Re: What did you do today lighting wise? « Reply #534 on: June 07, 2020, 03:19:22 PM » Author: fluorescent lover 40
I retired some lamps from use today. A Philips PL-S 13w/841 (Mexico - 1998), Regent F13TT 6400K (2001 - China - first working PL I ever got that has been through a lot of experiments and is now near EOL), and a Abco F7TT27K (UAE - 1991).
Meme Pods
A nice daylight CFL
UCKBWkfqE5WPMlFZmssITqPQ
Re: What did you do today lighting wise? « Reply #535 on: June 10, 2020, 09:04:34 PM » Author: Meme Pods
Got scammed
Down with the halogen bulbs
Re: What did you do today lighting wise? « Reply #536 on: June 11, 2020, 08:57:42 AM » Author: sox35
Got scammed
Ouch  :o  That doesn't sound good, what happened..?  :'(
Re: What did you do today lighting wise? « Reply #537 on: June 11, 2020, 03:13:13 PM » Author: xmaslightguy
Not today, but a couple days ago...
Replaced an EOL lamp in a bugzapper. Then I found the starter was also stuck, so took it apart to get at that...when I had it apart, I noticed the HV transformer for the zapping grid was fried, so sadly the unit is shot now. :(
Bulbman256
Mad Max
Bulbman256
Re: What did you do today lighting wise? « Reply #538 on: June 12, 2020, 06:46:05 PM » Author: Bulbman256
Went ahead and made sure everything is prepped for the movers today before they packed up my collection.
Re: What did you do today lighting wise? « Reply #539 on: June 13, 2020, 01:24:12 PM » Author: sox35
Started the mammoth task of sorting out our collection, we got as far as organising the crates with the HPS and MH lamps in, then my glasses broke (they got knocked off the shelf and one of the lenses fell out) so we're having to take a break while we see if they are repairable  :-\
