Author Topic: What did you do today lighting wise?  (Read 328584 times)
MissRiaElaine
Re: What did you do today lighting wise? « Reply #195 on: August 01, 2018, 12:14:52 PM » Author: MissRiaElaine
Fired up our newly acquired NOS GEC Trulite 125W MBF/U lamp  :mv: ;D
Re: What did you do today lighting wise? « Reply #196 on: August 01, 2018, 05:28:47 PM » Author: RyanF40T12
Today at a church building I swapped out about 60 Sylvania 3000k T8s for Sylvania 4100k T8s.  The 3000k's were too dim for the environment they were in.  The 4100k's do a much better job lighting the area.  I'll use the 3000k's at a few different buildings where the carpet and color tone are lighter and will do better in that area.  I still have quite a few more tubes to swap out but waiting for more 4100k to arrive.
Re: What did you do today lighting wise? « Reply #197 on: August 01, 2018, 05:59:48 PM » Author: funkybulb
Found a 30 watt American made Verilux tube at New Bransfels restore.
Re: What did you do today lighting wise? « Reply #198 on: August 03, 2018, 01:28:22 AM » Author: RyanF40T12
Today I went to another church building and took 2 cases of the 3000k T8s that I removed from the building yesterday and replaced a bunch of EoL or near EoL 3000k's.  Mostly Philips, but a few Sylvania.  Also replaced a bad GE T8 ballast.  There are a few more in this building but ran out of time.  It's about 70 miles away so I'll get back there next month or so.
Re: What did you do today lighting wise? « Reply #199 on: August 03, 2018, 10:35:02 AM » Author: Mandolin Girl
We are planning to put up a couple of little 6W T5 fixtures in the bedroom as reading lights. Mind you we have been saying that for months...  :D
Re: What did you do today lighting wise? « Reply #200 on: August 04, 2018, 02:34:02 PM » Author: Mandolin Girl
The queens of procrastination have struck again and they are still in the box... :a_fluor:
Re: What did you do today lighting wise? « Reply #201 on: August 06, 2018, 02:10:14 AM » Author: HomeBrewLamps
Saved a 175w westy lifeguard, and a 175w ballast..
~Owen
MissRiaElaine
Re: What did you do today lighting wise? « Reply #202 on: August 06, 2018, 06:49:30 AM » Author: MissRiaElaine
Built up a new test/display board for both 80W and 125W mercury lamps:
High Intensity
Re: What did you do today lighting wise? « Reply #203 on: August 14, 2018, 12:42:38 AM » Author: High Intensity
I'm fixing a Feit Electric CFL (mostly for fun), from what i can tell the resistor fuse randomly died for no reason.
Edit: Turns out the driver may have more issues than i thought.
« Last Edit: August 14, 2018, 02:11:59 AM by High Intensity » Logged
Re: What did you do today lighting wise? « Reply #204 on: August 14, 2018, 01:52:42 AM » Author: RyanF40T12
Today at once church building i swapped out a bunch of 3500k T8s for 3000k T8s.. I want to use up the 3rd Gen Sylvania Ecologic 3000k T8s as quickly as I can so thus the swap out.
At another building I replaced 2- 26 watt 4 pin CFL ballasts that were bad.  I also replaced 3 EoL 50 watt HPS bulbs.  got more work to do at this building.  A few 400 Watt MH bulbs that light up the steeple, 3 150 watt HPS parking lot bulbs, some cove lighting (strip lighting) F32T8 4100ks, and a few bad ballasts.  Ran out of time today.
Re: What did you do today lighting wise? « Reply #205 on: August 22, 2018, 04:28:15 PM » Author: Mandolin Girl
Finally received the ballast we've been waiting for to light our 1,000W Thorn Kolorlux mercury lamp, so we've built up a display board to light it up.
It certainly gets warm  :D
Re: What did you do today lighting wise? « Reply #206 on: August 22, 2018, 06:14:59 PM » Author: Mandolin Girl
:D
That it does, it's warmer than when I'm in there cooking.! ::)
boiler1011
Re: What did you do today lighting wise? « Reply #207 on: August 23, 2018, 04:24:40 PM » Author: boiler1011
I installed a LED upgrade package to my new 2018 Nissan Turbodiesel XD. They definitely light up the road a lot better than the stock halogens, and I do appreciate the fact that they match the stock LED headlights and running lights.
MissRiaElaine
Re: What did you do today lighting wise? « Reply #208 on: August 23, 2018, 04:32:56 PM » Author: MissRiaElaine
We broke our oldest (verified) lamp.  :'(
R.I.P. Thomas  :inc: :'(
MissRiaElaine
Re: What did you do today lighting wise? « Reply #209 on: August 23, 2018, 04:38:39 PM » Author: MissRiaElaine
What was it?
A 1950 GE 1000W incandescent, see here for a picture of it lit.
I was trying to screw it into the lampholder and used just a tad too much force, and the glass cracked  :'( :'( :'(
