Author Topic: What did you do today lighting wise?  (Read 328232 times)
108CAM
UCG6Xojn8dNgDuN9J7_Gnj8w
Re: What did you do today lighting wise? « Reply #1185 on: August 24, 2022, 08:01:40 PM » Author: 108CAM
I went back to the kinder upgrade project to see what else I could find and scored 2 5 foot battens and another 4 Philips Vandalites. There was also a 2 lamp LED floodlight designed to look like a 2 lamp PAR38 floodlight that I left because it's LED and I already have one in my collection.
1925-2002
Bring back the AJF Zodiacs!
Re: What did you do today lighting wise? « Reply #1186 on: August 24, 2022, 09:24:50 PM » Author: xmaslightguy
Not today, but last light-thing I did was..
Install a new lightfixture by the deck door to replace the one I'd taken down. (New fixture is still incandescent & infact got the same lamp that was in the old one)
Re-install the light by the shed door (fresh paint & it looks like a new fixture.)
{both walls also got painted which was the reason for removing the fixtures in the first place}
Re: What did you do today lighting wise? « Reply #1187 on: August 27, 2022, 10:25:39 AM » Author: Rommie
Got another couple of oily lampses today...  :oil-ltn:  :love:  :oil-ltn:  :love:
A Chalwyn Flag that was probably made in South Africa, and another Chalwyn Tropic, this one is stamped Mk2 with the date 1956.
I've had notification that another lamp is due to be delivered later today.  ;D
Re: What did you do today lighting wise? « Reply #1188 on: August 27, 2022, 10:45:09 AM » Author: Mandolin Girl
They're breeding  :mrg:
Re: What did you do today lighting wise? « Reply #1189 on: August 27, 2022, 12:13:32 PM » Author: Mandolin Girl
The third lampses has now arrived.  :oil-ltn:
I now have a Tempest to add to the family.  ;D
Re: What did you do today lighting wise? « Reply #1190 on: August 31, 2022, 12:35:50 AM » Author: xmaslightguy
Got into my "pile of junk lights" ...
A stack/pile of Christmas lights in the basement, containing all the lightsets(and there's LOTS of them) that quit-working/got-damaged/was-defective/etc(& I didn't feel like fixing) over what's probably a 2-3 decade period now).
108CAM
Re: What did you do today lighting wise? « Reply #1191 on: August 31, 2022, 12:43:42 AM » Author: 108CAM
Been trying to figure out how to mount lights in my limited space and without using the walls
1925-2002
Re: What did you do today lighting wise? « Reply #1192 on: September 01, 2022, 12:27:49 AM » Author: xmaslightguy
Repaired 8 sets of mini LED lights...
Most of the problems were caused by a bad LED, so a matter of find the bad one & replace it. I have a fairly quick & easy method to find 'em.
One set had a bad resistor..that took a bit more to figure out the issue there (& required snippers, strippers, soldering iron, heatshrink, + a resistor to fix)
(in addition to the 8 sets that got fixed, 5 went in the 'unfixable' pile)
So 13 sets dealt with so far...And that's just the beginning, there's still a large pile of lights waiting. .LOL. (whether or not the project is complete it gets ended last weekend of Sept (1st weekend of Oct starts put up time for the Christmas display))
Re: What did you do today lighting wise? « Reply #1193 on: September 02, 2022, 12:34:07 AM » Author: xmaslightguy
15 more sets of mini LED lights repaired this evening...
Re: What did you do today lighting wise? « Reply #1194 on: September 03, 2022, 11:24:44 PM » Author: xmaslightguy
Yesterday evening... 4 sets of mini incandescent lights repaired
Today... 18 more sets repaired
Re: What did you do today lighting wise? « Reply #1195 on: September 06, 2022, 12:00:27 AM » Author: xmaslightguy
Yesterday..
Fixed a dozen or so more sets of incandescent mini lights.
Unlike all the previous ones which needed defective/dead/broken/etc bulbs taken care of, these needed stuff like broken or defective sockets replaced....
Re: What did you do today lighting wise? « Reply #1196 on: September 07, 2022, 11:57:17 PM » Author: xmaslightguy
Yesterday evening..
Repaired 5 sets of mini lights. These sets had wires that'd become damaged at some point.
This evening..
Repaired 7 sets of mini lights. 1 had a cracked socket, 1 had a wire that was never connected at the factory, the rest all had dangerous factory defects like bare spots on wires.
Also repaired 2 sets of LED lights. 1 with a bad solder joint on its resistor, 1 with a damaged wire.
« Last Edit: September 08, 2022, 12:52:01 AM by xmaslightguy » Logged
Re: What did you do today lighting wise? « Reply #1197 on: September 08, 2022, 11:21:35 PM » Author: xmaslightguy
This evening..
Five sets of LED lights fixed, which involved:
1 cracked socket replaced
2 bad resistors replaced
1 wireing defect repaired
1 damaged wire repaired
Re: What did you do today lighting wise? « Reply #1198 on: September 09, 2022, 01:36:31 AM » Author: joseph_125
Tonight:
Testing some used 55w SOX lamps I bought. So far so good. Now I can store the NOS Osram one I have until I use up these used Philips lamps.
108CAM
Re: What did you do today lighting wise? « Reply #1199 on: September 09, 2022, 07:51:28 AM » Author: 108CAM
1200 replies! Keep it up!
1925-2002
