Econolite03
Matthew E.
You ‘gals’ are from Europe yet you don’t know Pink Floyd? That’s it…
Gemma + LED Retrofit = awesomeness.
We aren't from Europe, we're from the UK As for Pink Floyd, I know of them, but I'm not a fan, so haven't ever listened to them or watched any of their videos. And pretty please stop mentioning our lovely Gemma in the same sentence as those over-excited semiconductors
How about dudes?
No, those are blokes (guys if you must) Right, that's enough of a let's get back on topic, shall we
Replaced the last of my 100w equiv. Feit daylight filament style LEDs over my drive way I actually got around 7,500 hrs. from this POS running D2D for 2 years , 7 months !! Longest lasting one yet !! The replacement is an Ecosmart version which is 100 lumens brighter (1,600L) and used 1 watt less ! (15w vs 16w) . So far , I've had great luck from the Ecosmart lamps...We'll see !!!
Today we received some rather nice Philips spectral lamps, so we're lighting those up. Photos to follow
thelightingman
All lighting except LED rules!
Yesterday I got a 39 watt CMH pendant light from my local ReStore for $10. It had a brand new lamp in it but the ballast was bad. Luckily I had another one of those pendant lights I had gotten from that same ReStore so I stole the ballast out of it. The light works perfectly now and is quite bright.
I think HPS, MV, and MH rule! Ban LED instead!
108CAM
A few days ago I went on a train trip to pick up 2 unboxed but NOS 175w MV Holophane ceiling mount fixtures. Normally I wouldn't go by train to pick up lights but because it was only $50 for both, I couldn't pass. Apart from some rain, everything worked out and before I knew it, I was back on the train going home. I'm glad I went outside of rush/peak hour because it meant I could sit the 2 bags and box with the lights on the seats which was good due to how heavy they were.
Rest in Peace Electronic Lamp Manufacturers of Australia 1925-2002
Bring back the AJF Zodiacs!
Total incidents since joining LG: 18 Lamps accidently broken or smashed: 15 Ballast explosions/burnouts: 3
Bulbman256
Mad Max
Changed a couple lamps today, even saw one arc between the filament gap and managed to get a good photo of it while on.
Swapped out a ballast in a 3ft striplight. I had a HPF 30w only ballast and I decided to try that one out instead.
bulb_tester2009
Our delivery will be restored the day after tomorrow, and some fluorescent tubes and ballasts will arrive (including my coveted Philips SL*9 CFL)
I've been collecting light bulbs since I was 2 years old and I've been collecting them ever since. One of the few Chinese users here Note: Bulb base in China:E12(CES) E14(SES) B22d(BC) E27(ES) E40(GES)
108CAM
I lugged 2 Sylvania Batwings home using a flatbed shopping cart. It was very tiring due to how heavy the lights are but was very much worth it in the end
Molly
The wild Lampent hates LEDs!
Had to change my lizard's basking bulb because it blew out.
If you want to use any of my photos, please ask me for permission, and make sure to add credit. Thank you!
fluorescent lover 40
I replaced a Feit 100w equivalent 2700K filament LED that lasted a little over year, used on average five hours a day, with a new one. Hope it makes it more than one year lol.
Silverliner
Rare white reflector
Enjoying the 30 NOS Westinghouse Super Bulbs that I got off eBay for $35. 29 60w and 1 100w.
Member of L-G since 2005.
Electrician.
108CAM
Some of the lighting related stuff I've done recently I dug out some light bulbs I packed for a house move that never happened. I accidently broke a bulb but am not upset as it was burnt out prior to shattering. I've started restoring and cleaning up my Sylvania Batwings I built my first prototype for a vertical fluorescent column light And lastly, I've gained a bit more confidence with metal halide lamps and plan to run up a 70w MH lamp then hopefully have the confidence to fire up my Batwings.
