Author Topic: Death Lights  (Read 5539 times)
Death Lights « on: September 08, 2016, 08:53:04 PM » Author: wattMaster
My tabletop studio halogen lights are doing well. But after leaving them on, I checked the temperature of the plastic enclosure, and it was over 300 degrees! :o
And that's in a cold room.
Are they going to melt and cause a fire?
« Last Edit: September 08, 2016, 09:10:12 PM by wattMaster » Logged
nicksfans
Down with lamp bans!
Re: Death Lights « Reply #1 on: September 08, 2016, 10:13:04 PM » Author: nicksfans
If they have the correct wattage lamps installed, they should be fine.
My Gallery
Instagram
YouTube
Re: Death Lights « Reply #2 on: September 08, 2016, 10:18:44 PM » Author: wattMaster
They were 50 Watt Halogen GU10 lamps.
nicksfans
Re: Death Lights « Reply #3 on: September 08, 2016, 10:19:08 PM » Author: nicksfans
Is that what the fixture is rated for?
My Gallery
Instagram
YouTube
Re: Death Lights « Reply #4 on: September 08, 2016, 10:19:36 PM » Author: wattMaster
It doesn't say anything about that.
nicksfans
Re: Death Lights « Reply #5 on: September 08, 2016, 10:20:10 PM » Author: nicksfans
Are those the lamps it came with?
My Gallery
Instagram
YouTube
Re: Death Lights « Reply #6 on: September 08, 2016, 10:20:58 PM » Author: wattMaster
They came with it.
It also smelled like burning plastic, not that I actually know what burning plastic smells like.
nicksfans
Re: Death Lights « Reply #7 on: September 08, 2016, 10:23:32 PM » Author: nicksfans
It's probably fine then.
My Gallery
Instagram
YouTube
Re: Death Lights « Reply #8 on: September 08, 2016, 10:25:27 PM » Author: wattMaster
I find that LED does well in these lights, so I might be doing that.
Re: Death Lights « Reply #9 on: September 09, 2016, 08:18:37 AM » Author: Ash
Smell of burning plastic from a luminaire i would not consider as probably fine.. You can expect the plastic melting or otherwise degrading after some use
If this luminaire is relatively new it might have been made for LEDs exclusively
Re: Death Lights « Reply #10 on: September 09, 2016, 04:02:58 PM » Author: AngryHorse
50watt GU10 halogen lamps are not good!, I have pulled them out at work when they start to melt nearby wiring!!, if you can smell burning of any kind, then something isn`t right?
Current: UK 230V, 50Hz
Power provider: e.on energy
Re: Death Lights « Reply #11 on: September 09, 2016, 04:28:15 PM » Author: Ash
They are good when used in good luminaires, and those should have a label on them specifying how close can stuff be in front of the lamp
nicksfans
Re: Death Lights « Reply #12 on: September 09, 2016, 04:29:53 PM » Author: nicksfans
If it really did originally come with those lamps and it really is smelling like burning plastic, then it was not designed well at all.
My Gallery
Instagram
YouTube
Re: Death Lights « Reply #13 on: September 09, 2016, 05:17:38 PM » Author: wattMaster
I think this is what these lights are. But the good news it that it says that you will be normally be smelling a burning smell, but the plastic is not melting.
Sounds a little odd.
« Last Edit: September 09, 2016, 05:40:57 PM by wattMaster » Logged
Re: Death Lights « Reply #14 on: September 09, 2016, 05:41:05 PM » Author: Ash
It may not be melting, but its outgassing from the heat. Which means it is deteriorating. And i dont think those fumes are healthy to inhale either
