Author Topic: Pole top cut out fuses  (Read 7925 times)
Re: Pole top cut out fuses « Reply #15 on: August 17, 2016, 12:00:00 PM » Author: sol
If there was smoke, I didn't see it as I wasn't at the window when it happened. It took several seconds before I realised what happened and that I lost mains power. At first, I thought a large bird had collided in a window. It could very well be a bird that caused this but I think it has more to do with salt spray. About two hours after the fuses were replaced, I lost power again but this time it was a widespread outage that lasted a couple hours.
hannahs lights
Re: Pole top cut out fuses « Reply #16 on: August 17, 2016, 01:15:13 PM » Author: hannahs lights
Hey Sol that's just plain unlucky  I wonder if your local fault caused a problem further up the network hope your power stays on now
Re: Pole top cut out fuses « Reply #17 on: August 17, 2016, 04:13:29 PM » Author: sol
Everything seems fine now. Actually, it is the neighbour's transformer that blew the fuse. Mine stayed intact. It blew the fuse of the line going up my road as well, that is why I had no power.
Re: Pole top cut out fuses « Reply #18 on: August 18, 2016, 08:31:38 AM » Author: RyanF40T12
https://www.youtube.com/watch?v=UF5EDV6T7es
