Author Topic: Is this rare!?  (Read 7056 times)
Is this rare!? « on: July 22, 2016, 12:51:19 PM » Author: Lumex120
http://brainerd.craigslist.org/for/5688866620.html
I just found this when I searched "Mercury vapor" on the local craigslist. You have no idea how startled I was to see it, all I was expecting to see was yardblasters. It is near my cabin, and I am going to try and get rid of more stuff so I can get it. Is it rare?
Unofficial LG Discord
Re: Is this rare!? « Reply #1 on: July 22, 2016, 01:00:44 PM » Author: Solanaceae
It kinda looks like a 60s head, judging by the label. I've seen that GE had gumballs as late as the 60s, so this could be late production, or also a retrofitted Incan gumball. Judging by the green thing it looks to have been for series wiring originally, and it kinda looks like it has a bullethole on the side, tho.
Re: Is this rare!? « Reply #2 on: July 22, 2016, 01:01:26 PM » Author: wattMaster
You could make your own with an MH ballast, but I have never seen this before. Looks rare.
Re: Is this rare!? « Reply #3 on: July 22, 2016, 01:07:06 PM » Author: Lumex120
It says "Westinghouse" and "175 watt mercury vapor lamp" on the socket so I assume it is original. As for the bullet hole, could it be fixed?
Re: Is this rare!? « Reply #4 on: July 22, 2016, 01:08:16 PM » Author: wattMaster
What bullet hole? Was this a shooting target?
Re: Is this rare!? « Reply #5 on: July 22, 2016, 01:09:20 PM » Author: Solanaceae
See that black hole above the insulator? Unless it's something on the housing or an image anomaly.
Re: Is this rare!? « Reply #6 on: July 22, 2016, 01:12:36 PM » Author: Lumex120
Could it be fixed?
Re: Is this rare!? « Reply #7 on: July 22, 2016, 01:14:18 PM » Author: Solanaceae
Do you kno any metal workers? You could patch it with some jb weld and paint over it to match the color of aluminum. Or as a temp fix a large enough bolt.
Re: Is this rare!? « Reply #8 on: July 22, 2016, 01:45:17 PM » Author: Lumex120
I would probably just use JB weld. Also, is it possible that the bullet damaged the ballast? If so, could I fit a Plusrite M57 ballast in it?
Re: Is this rare!? « Reply #9 on: July 22, 2016, 01:51:53 PM » Author: Solanaceae
Does he have the ability to test it or remove ballast?
Re: Is this rare!? « Reply #10 on: July 22, 2016, 02:08:30 PM » Author: wattMaster
It doesn't take much to test it, just some careful wiring.
Re: Is this rare!? « Reply #11 on: July 22, 2016, 02:27:34 PM » Author: Solanaceae
But then again, he may not want to or be willing to buy a new lamp.
Re: Is this rare!? « Reply #12 on: July 22, 2016, 02:37:21 PM » Author: Lumex120
Even if it doesn't work, I still want the housing.
Re: Is this rare!? « Reply #13 on: July 22, 2016, 02:41:05 PM » Author: wattMaster
There's the possibility of getting molds and fabricating your own, out of molten metal.
Re: Is this rare!? « Reply #14 on: July 22, 2016, 03:34:31 PM » Author: Lumex120
That is WAY beyond my ability. Plus, where would I get a refractor and mold?
