veryhighonoutput
![](/avatars/Musicians/Korn.jpg)
T12
Like f48 pgs and f90t17's when there junk??? I hate to destroy or recycle but I have no room ether!
![](https://www.lighting-gallery.net/index.php?PHPSESSID=bd7269c0dc9c58599e359c25a41cd6e2&action=dlattach;attach=4881;type=avatar)
I don't have any, but I would reuse them as a sleeve for other tubes, or maybe for testing germicidal lamps, or put a working lamp lit in them to light it up.
Well, if you manage to cut out the ends without breaking the tube... Plus in any way the thin glass tube will be extremely fragile...
![](https://www.lighting-gallery.net/index.php?PHPSESSID=bd7269c0dc9c58599e359c25a41cd6e2&action=dlattach;attach=432;type=avatar)
And if you manage to not scratch off the Phosphor when using it as a sleeve..
How about backlighting the tube with a T5 or some CCFLs
Assuming you have enough, you could build a fixture like this or like this.
![](https://www.lighting-gallery.net/index.php?PHPSESSID=bd7269c0dc9c58599e359c25a41cd6e2&action=dlattach;attach=3025;type=avatar)
"Fluorescent lamps are synonymous with the most depressing aspects of modern life: their soulless flickering presides over vast aisles of big box stores, server farms , fields of cubicles, or server farms." ha! Classic! You're good! My version: LED lamps are are synonymous with the most depressing aspects of modern life: their soulless flicker presides over every single use, causing migranes and casting an unappealing off white hue.
My version: HPS lamps are synonymous with ugly, strobing orange light that fills streets with a horrid glow.
Well, "the most depressing aspects of modern life" could be any form of lighting, if you do the fixture design in a careless way. And the main part of the "fixture design" is the proper selection of the fixture concept. The same tube could be a soul-less light, as well as a center piece of an artistic creation. It only depends on in how and where it is used.
I dont think it is related much to the lighting at all, but to anything else that is performed under the same lighting. For one who works too many hours in a cubicle any type of lighting thats used in his cubicle will be associated with depression... And the /640 Fluorescents were just there to get the bad name
veryhighonoutput
T12
I was thinking of making a ultimate egg holder with the power grooves just hot glue it on a board and whala! Egg holder you could even color them for easter in each individual groove wow! Or Dimond cut one end off and stuff Christmas lights down in. Or donate to a museum or something. So many possibilities .
And you wonder why 8000K fluorescents don't get the bad press, while the standard cool white ones do. ![Undecided :-\](/Smileys/default/undecided.gif)
The standard CW ones are what was installed in cubicles at the time when it was "Incandescent at home vs Fluorescent at work", so when all that bad press was forming up first time. Like in the 60s/70s
Then the health nuts came, with silly claims about Cool White...
« Last Edit: July 18, 2016, 05:10:34 PM by wattMaster »
And claims that appear plausible. After all. CRI 60 is not CRI 70/80/90, i is indeed visible that the light qulity of those tubes is not too high. Little do they (or the ones they try to convince) know that CRI or light quality is not directly related to health effects, it is the spectral content that is.. Fun thing is that old warm color tubes have CRI in the 50s, their light is indeed very poor, yet there were way less claims in regards to them being depressing or anything
Maybe it's the correlation with gloomy offices. I actually like old-school WW, it has a nice, "feel" to it, and makes colors look funny.
