Author Topic: New mercury vapor bulb break in.  (Read 3065 times)
bucket175mv
New mercury vapor bulb break in. « on: July 16, 2016, 09:01:52 AM » Author: bucket175mv
Hi there.
I have a question regarding new :mv:lamps. Do they have an initial "break in" or run in time?
Is the lamp light output more intense for, let's say the first 200 or so hours of operation?
Reason I ask is because I just finished building and installing a 50 watt :mv: yard light and it's mega bright for the rated 1800 lumens. I hope it calms down some after a few months of dusk to dawn operation!
Re: New mercury vapor bulb break in. « Reply #1 on: July 16, 2016, 11:20:57 AM » Author: dor123
As mercury vapor lamp, is an unsaturated vapor HID lamp (All the mercury is in the vapour state), theoretically they don't need an initial running cycle, despite I did this with my SBMV lamps, when they were new. HPS and MH lamps more need this initial running cycle for their color to stablise, as they are considered saturated vapor lamp. In some cases, fluorescent lamps also need a running time of several hours, when operated for the first time, to get their mercury to reach equilibrum.
Re: New mercury vapor bulb break in. « Reply #2 on: July 16, 2016, 11:31:53 AM » Author: wattMaster
I don't think MV needs break in, but MH lamps are "seasoned" after about 100 Hours.
bucket175mv
Re: New mercury vapor bulb break in. « Reply #3 on: July 16, 2016, 11:58:28 AM » Author: bucket175mv
Himm I see. I thought I read that somewhere that MV lamps do this also.
Re: New mercury vapor bulb break in. « Reply #4 on: July 16, 2016, 12:52:23 PM » Author: Ash
The changes to full power mode would be very subtle if any, and probably not visible in respect to brightness - as even if there is some slight brightness difference, our vision "corrects" it so we still dont see anything
If anything, i'd expect to see either variations in the flicker of the lamp (rectification) or in the warm up show
If it is too bright, consider changing the ballast or adding some more ballasting impedance in series
Re: New mercury vapor bulb break in. « Reply #5 on: July 16, 2016, 02:48:19 PM » Author: AngryHorse
This is where its handy to have the lumen maintenance graphs.
The standard MV lamp will drop to 90% of its original lumens at 4000 hours, (Philips lighting catalogue 1994 data for one year typical dusk to dawn running), however, you won`t see this by eye!
My current 50watt MV lamp, (French Sylvania), in my front yard light will be 2 years old this December, but still looks as bright as it was when it went in! 8), even though its now passed the 90% mark.
« Last Edit: July 16, 2016, 02:50:23 PM by AngryHorse » Logged
Current: UK 230V, 50Hz
Power provider: e.on energy
Re: New mercury vapor bulb break in. « Reply #6 on: July 16, 2016, 03:33:57 PM » Author: Ash
I doubt 1994 data is applicable at all to today's lamps.. Definitely not to Chinese 125's
Re: New mercury vapor bulb break in. « Reply #7 on: July 16, 2016, 04:58:40 PM » Author: AngryHorse
LOL, yeah fair point, that was back when MV were built to their best!
bucket175mv
Re: New mercury vapor bulb break in. « Reply #8 on: July 17, 2016, 08:06:36 AM » Author: bucket175mv
What other ballast options do I have for this 50w MV lamp? If I added a resistor in series with the lamp, wouldn't the resistor get very hot to the point of failure?
bucket175mv
Re: New mercury vapor bulb break in. « Reply #9 on: July 17, 2016, 08:12:33 AM » Author: bucket175mv
I see what you mean and your 50w MV yard light looks just as bright as mine does. Maybe I should switch to a clear 50w MV lamp. Would this help?
Re: New mercury vapor bulb break in. « Reply #10 on: July 17, 2016, 11:34:45 AM » Author: Medved
Well, clear MV definitely emits less light, but as well way lower CRI (barely 15), mainly there is just no red whatsoever. But if that adds the mood, it may work. Worth to try, but if you manage to still find some clear lamps...
Re: New mercury vapor bulb break in. « Reply #11 on: July 17, 2016, 01:25:07 PM » Author: AngryHorse
Is there a problem with its brightness?, a neighbour issue, or just your own observation?
bucket175mv
Re: New mercury vapor bulb break in. « Reply #12 on: July 21, 2016, 07:11:10 AM » Author: bucket175mv
To be honest, I've got no angry neighbors and the only issue I can really see is that the light does reach across the street and  lights up the front of my neighbors house slightly. Again, no complaints. So it really is just my observation.
I'm surprised that this 50 watt MV bulb/ballast is as bright as a 100w MV bulb/ballast, cannot figure out why. They both have different lumens ratings! The only advantage is that this fixture uses less power.
Re: New mercury vapor bulb break in. « Reply #13 on: July 21, 2016, 02:19:34 PM » Author: Medved
Better check, if the ballast really is what you expect it to be (measure the output current; a regular AC A-metter should be good enough, the current is very close to a sinewave). If it isn't by some mistake just e.g. a 70W type with a wrong label... In that case the real power will be very close to 100W, so will be the light output. Only the lamp life will be quite shorter...
The 35W MH should feed the lamp by 0.5A, the 50W MV lamp is rated for 0.6A.
A 70W MH is 0.95A, 100W MH will be around 1.25A.
dischargecraze
Tom
Re: New mercury vapor bulb break in. « Reply #14 on: July 28, 2016, 10:31:02 AM » Author: dischargecraze
Well I thought you had to let the mercury vaporize completely for a couple of hours. Because when the lamp is new the phosphor tends to be very red and when that had gone away it would run the right way.
