Author Topic: Black Light Identification  (Read 2422 times)
Black Light Identification « on: July 09, 2016, 03:10:15 PM » Author: wattMaster
How do you identify the phosphor used in Black Lights?
The package/etch for the tubes doesn't help, and are there any ways to specifically know what is used on the Philips black light F15T8s?
Re: Black Light Identification « Reply #1 on: July 09, 2016, 03:16:28 PM » Author: Solanaceae
There're the BLB lamps (the deep purple ones; they used to be made with woods glass, now it's an enamel coat over the glass) and then the uv phosphor ones used in bug zappers and also some rock fluorescent analyses.
Also the clear ones (not really black lites) used in germ bulbs.
« Last Edit: July 09, 2016, 03:19:25 PM by Solanaceae » Logged
Re: Black Light Identification « Reply #2 on: July 09, 2016, 03:32:04 PM » Author: wattMaster
No, I'm talking about BLB, there are several phosphors used in those, and I want to know how to identify the phosphors used in them.
« Last Edit: July 09, 2016, 03:45:02 PM by wattMaster » Logged
RCM442
Re: Black Light Identification « Reply #3 on: July 09, 2016, 04:01:37 PM » Author: RCM442
I'm pretty sure they are all the same phosphor
Administrator #4
Re: Black Light Identification « Reply #4 on: July 09, 2016, 04:04:05 PM » Author: wattMaster
There's at least two of them, with different compositions, I think.
Re: Black Light Identification « Reply #5 on: July 09, 2016, 04:38:18 PM » Author: Medved
I know about at least two general types of UV fluorescent phosphors:
One type generates just the long wave UVA and is used in BL and BLB (the BLB has an extra filter blocking all the visible coming directly from the mercury discharge itself).
Then are the tanning bed types, generating shorter wave UVB as well.
And within each category, the actual compositions may vary among evolution and manufacturers as well.
I would guess an accurate spectral analysis may tell way more, similar as with the visible. Maybe with the BLB it would require to peel off some of the filter coat (in the recent years, the fluorescents do not use a real Woods glass, but actually just a common glass and the filter is then in the form of lacquer applied onto the tube; one of the reasons is the difficulty to work with the way more fragile Woods glass, it's cost and recently the fact the composition of the Woods glass does not meet the ROHS directive)
Re: Black Light Identification « Reply #6 on: July 09, 2016, 05:28:23 PM » Author: Ash
Diffract the light with a prism and project on a Fluorescent screen ?
Re: Black Light Identification « Reply #7 on: July 09, 2016, 05:29:34 PM » Author: wattMaster
Problem is, all of the spectrometers we can affordably use are not accurate enough to identify the phosphor.
