Usually european (well UK as I know) have something like: "3x0.75mm2" which means that there is 3 cores, usually live, neutral and earth, and the 0.75mm2 means the conductor is 0.75mm2. For lighting etc, I use at least 1mm2.
You also get 3G0.75mm2 which is just the same as the above.
