Author Topic: Fluorescent dimmer on the cheap  (Read 2220 times)
Fluorescent dimmer on the cheap « on: April 05, 2016, 08:57:29 PM » Author: sol
I was in the diagnostic imaging department of a small local hospital today and the fluorescent lights were dimmed down quite a bit. Naturally, I started thinking about this when I had this crazy idea.
With series magnetic RS, if you take out one lamp, the other one goes out. If you take out the other lamp instead, the first one stays dimly lit. Now I have a couple of Philips Advance Rapid Start Electronic ballast model number RELB-2S40-N. When you take out the lamp that leaves the other one glowing, it glows quite a bit, maybe around 30-40% instead of the 5-10% of the magnetic ballast. My "plan" (which I don't really plan on making but thinking never hurts) would be to put in a relay on the wires leading to that lamp to take it out of the circuit and then when the other lamp stays in the circuit, it would be dimmed.
I'm guessing there would be quite a few reasons why this wouldn't be feasible (it wouldn't pass code for one thing) but hey, it's an idea. ;)
nicksfans
Down with lamp bans!
Re: Fluorescent dimmer on the cheap « Reply #1 on: April 06, 2016, 12:35:52 AM » Author: nicksfans
Unless the ballast heats the cathodes constantly like an RS ballast, this will sputter the lamp that is left in the circuit.
My Gallery
Instagram
YouTube
Re: Fluorescent dimmer on the cheap « Reply #2 on: April 06, 2016, 01:17:42 AM » Author: Medved
What keeps the "other" lamp slightly glowing with the RS ballast is the bleeder capacitor or resistor parallel to the Neutral lamp. Normally it's function is to prevent the ballast OCV from evenly distributing across the series lamps when they are not yet ignited, but rather expose one lamp to the full voltage and once it ignites, it's low drop will overcome the bleeder impedance to expose the other one to the nearly full voltage, so it as well easily.
When you remove the lamp parallel to the bleeder, what you get is essentially a high impedance ballast for the remaining lamp, so in fact powers it with low current, hence the dim light.
Normal HPF RS ballasts use capacitors as the main ballasting impedance. So when you make it switchable, you may alter the actual lamp power.
As RS ballasts provide constant heating power, the cathodes should be fine. They will run slightly cooler, but on the other hand the current is low, so even when restricted, the emission should be sufficient.
The concept of the electronic may be the same, differing only in the operating frequency. The high frequency then makes even low value capacitor passing way higher current (with many designs the capacitor bleeder is nothing else than just a stray capacitance of the interconnect wires to ground) than the 60Hz magnetic, so the remaining lamp glows brighter. Or because even the capacitance between the lamp body and ground is quite significant, you may easily get just partially lit tube, with the intensity gradually decreasing towards the cold end. Many people here tend to misjudge that with mercury starvation or other lamp atmosphere defects. But unlike with the atmosphere defects, here the lamp runs cold and the brightness increases when you touch the lamp. It may glow pink, when the low temperature is not sufficient to evaporate the mercury, so pink just glow is not reliable indicator, whether it is electrical, or chemical problem. For this partial glow, one reason may be missing filament supply and/or cathode failure (so effectively disconnecting the arc), mainly with easy to ignite lamp shape/chemistry (when the ignition voltage is lower than the cold cathode fall).
But back to the dimming: Electronic ballasts may be connected in many different ways, each behaving differently when you remove one lamp, very frequently stressing the internal ballast components. With better quality ballasts the ballast just senses the lamp failure and just shuts down to protect itself.
So generally I would not do that way. It is strongly dependent on the actual ballast topology. If you have some particular ballast, it is way easier to just modify that ballast for the dimming operation, provided the ballast has some means to power the filaments.
With RS ballast it will be an extra capacitor in the lamp circuit (but the filament winding has to remain connected to the filaments; the capacitor works well with both HPF, as well as the NPF shoplight ballasts, you only need to gain access to the internal connections).
With electronic using dedicated ballast IC the simplest way is to increase the operating frequency by changing the timing component (but you will need either a relay or optocoupler for that, as the connections to those elements should remain very short, to not pick up any noise). With the frequency change the typical lamp filament circuits automatically generate filament power (I haven't seen any mains powered HF ballast circuit, which wouldn't do so). The only problem is, you can not go below about 30% brightness without any lamp current monitoring feedback or so, without the circuit becoming too temperamental and/or even unstable.
All the HF dimmable ballasts use the frequency change, they just use some sort of feedback system to monitor the arc in the lamp (via arc current and/or impedance caused phase shift sensing) and are constantly adjusting the frequency so, the lamp brightness remains where it is commanded by the setting.
Re: Fluorescent dimmer on the cheap « Reply #3 on: April 07, 2016, 08:24:52 PM » Author: sol
Thanks for the info. I knew it wasn't feasible but didn't quite know why.
OK, here I am daydreaming out loud. A less expensive solution to a dimming fluorescent would be to install a couple of low wattage PL lamps in let's say a troffer. These would be switched separately from the main lamps and could be used as a dimmer. Not as elegant as a proper dimmer but could work. My idea above is not really an elegant solution either...
hannahs lights
Re: Fluorescent dimmer on the cheap « Reply #4 on: April 08, 2016, 04:06:23 PM » Author: hannahs lights
Even easier use a variac start on full volts  ie 110 or 240 to get the lamp going then back it off to the desired level. Easy as
Re: Fluorescent dimmer on the cheap « Reply #5 on: April 09, 2016, 12:26:41 PM » Author: Medved
Well, variac is enything but cheap and second, many mainly electronic ballast will get fried when exposed to long time input undervoltage (the PFC input stage will operate on higher currents than normally), yet there will be no effect on lamp power (the PFC maintains the intermediate voltage on preprogrammed level).
And with ballasts without regulation (so all magnetic and many cheaper lower power electronic) it would mean there is no or way insufficient supplemental heating power for the dimmed lamp, so the arc becomes unstable and generally the lamp will suffer.
Really the only way is to get or assemble really decent dimmable ballast, for two or three levels that is not that difficult, e.g. heating transformer and switchable set of chokes or series capacitors (normal power means just the coil in the circuit with the capacitor bypassed by the power selector switch, low power means the switch  opens and the capacitor is let to become in series of the circuit). Both you may get with proper safety rating.
