Author Topic: Varnish curing  (Read 1546 times)
Varnish curing « on: March 25, 2016, 09:08:37 PM » Author: Solanaceae
I'm planning to get some red varnish or glyptal enamel to have on hand if I wanted to revarnish worn ballasts. Would putting the varnished ballast in the oven set at 250°f (120 ish °c) be a good alternate to running the ballast in a fixture if a fixture wasn't readily available?
Re: Varnish curing « Reply #1 on: March 26, 2016, 12:46:42 AM » Author: Medved
I wouldn't run the ballast at all before it dries out. The liquid varnish does not provide the protection against vibration and mainly evaporates solvent fumes...
I think one of the best methods is to let it dry on  direct sunlight of a hot summer day. But that obviously works only part of the year...
toomanybulbs
Re: Varnish curing « Reply #2 on: March 27, 2016, 06:09:11 PM » Author: toomanybulbs
hopefully you are properly vacuuming them while immersed.otherwise you are wasting your time and material.i let a freshly rewound transformer soak overnight in a can.
in the morning i pulled a vacuum on the can and got a huge amount of bubbles.held it for several hours till i didnt see any more.let it drip drain overnight and only then did i bake at 275f a few hours.
it was all done with stinking at that point.so my room didnt smell every time the amp was run.
Re: Varnish curingv « Reply #3 on: March 27, 2016, 08:05:52 PM » Author: Solanaceae
Yeah I would, would a conveniently sized rubbermaid container and shop vack work?
