Author Topic: European 25w 970mm T12 fluorescent lamp?  (Read 2512 times)
European 25w 970mm T12 fluorescent lamp? « on: January 16, 2016, 03:26:58 AM » Author: Roi_hartmann
I recently acquired this old book from 1975 called "Sisustamme valolla" (Decoration with light) which was written by Eino Lampi from Airams R&D. In that book there is a list of standart fluorescent lamp wattages and sizes. What troubles my mind is that there is listed a lamp that is 25W T12 with lenght of 970mm. I guess that modern version would be 23W T8 which has same lenght? I have never seen such lamp myself but was just wondering what kind of applications such lamps were used and is it a commond wattage in other parts of Europe?
Heres a picture of that list: http://www.whitenightcape.com/kuv/WP_20160116_10_09_48_Pro.jpg
Re: European 25w 970mm T12 fluorescent lamp? « Reply #1 on: January 16, 2016, 04:56:13 AM » Author: funkybulb
33 inch T12 25 watt tube seemed once common tube in USA .
Re: European 25w 970mm T12 fluorescent lamp? « Reply #2 on: January 16, 2016, 06:34:12 AM » Author: Ash
Not sure about this lamp. I recall seeing a 1080mm long 40w lamp specified on a Thorn EMI ballast from Britain (that came in a 38W 2D lantern)
Michael
Re: European 25w 970mm T12 fluorescent lamp? « Reply #3 on: January 19, 2016, 03:55:16 AM » Author: Michael
These were the first fluorescent lamps which have been marketed here in Europe by Philips known as Philora TL100 with the lenght of 970mm, 25W and 100Deka Lumen.
These size was not that common. Mostly found in show cases and signs. The T12 25W tube was replaced later by the 23W T8 for energy savings. It has the same physical lenght as the 36/40W 1m which is rare as well.
Re: European 25w 970mm T12 fluorescent lamp? « Reply #4 on: January 19, 2016, 10:57:05 AM » Author: Medved
I think this size is used in older trams - with resistive ballasts, two in series, on 600VDC...
nicksfans
Down with lamp bans!
Re: European 25w 970mm T12 fluorescent lamp? « Reply #5 on: January 19, 2016, 03:10:10 PM » Author: nicksfans
@funkybulb: 970mm is about 38 inches, which doesn't correspond to any North American lamp that I'm aware of.
My Gallery
Instagram
YouTube
Re: European 25w 970mm T12 fluorescent lamp? « Reply #6 on: January 20, 2016, 05:09:03 AM » Author: Roi_hartmann
Thanks for the info. I guess that it may have been some mistake to include that lamp for listing since it not really with common lamps.
There was also this other very interesting lamp called heijastinlamppu. It's standar shape incandescent lamp that is partially opaque. The top part of the lamp is clear. Idea seems to be that this lamp would be wide angle spotlight that also would shed some light for other directions aswell. There is crappy black and white picture of such lamp but otherwise I have never seen such lamp nor there is any mention about such lamp in Catalogs I have.
trojmiejski
Re: European 25w 970mm T12 fluorescent lamp? « Reply #7 on: June 06, 2016, 01:35:53 PM » Author: trojmiejski
While a little bit of time passed since the last post but I have some info where such tubes are still present. 25W tubes in Central Europe can be associated with railways. When in 1950s fluorescent lighting first appeared in passenger cars and electric motor units (EMU), 25W tubes were first used, with 20W and 40W appearing later. Factories in GDR were first to produce rolling stock with such tubes and in Poland, Pafawag Wrocław soon followed. First EMU from Pafawag with such lighting system was EW55 which rolled from assembly line in 1958. It served as the basis for EN57 which was produced from 1961 to 1993. EN57 inherited technical solutions from its predecessor and during the course of production very little changes were made. The result is that in 1990s there were still made EMUs with archaic system of 25W tubes powered by a motor-alternator set while simultaneously made newer constructions were given up to date inverter technology designed to be used with 18W/20W and 36W/40W tubes. Many EN57 were since scrapped or heavily refurbished but there is still a great amount of 25W tubes to be seen around. Here are examples of such tubes: http://www.lighting-gallery.net/gallery/displayimage.php?album=230&pos=26&pid=121348
http://www.lighting-gallery.net/gallery/displayimage.php?album=230&pos=27&pid=121347
Apart from this EMU series from Poland I've seen such tubes in passenger cars from 1980s belonging to Czech Railways, made in GDR by Waggonbau Bautzen.
