Author Topic: Inquiry on Cooper Lighting, Model NH1204M  (Read 25324 times)
Pj
Re: Inquiry on Cooper Lighting, Model NH1204M « Reply #60 on: October 11, 2016, 04:50:01 PM » Author: Pj
There you go, use that screw to set the tripping point.
Any experience with that screw?
How many turns or fraction of a turn?
The new controller has a 90-day 'warranty',
so do I wait or go ahead and try it?    :)
I messed-up the relay in the old one,
so it's now the 'always on' backup.   ::)
"I know just enough to be dangerous."   :mv: ;D
Re: Inquiry on Cooper Lighting, Model NH1204M « Reply #61 on: October 11, 2016, 05:10:35 PM » Author: Ash
Looks like turn the screw in to tweak it towards the open position. Push the screw (the bimetal strip) and see if this indeed opens the contact
Turn the screw somewhat in that direction
Try to push the screw again to see how the contact opens, and when you release then how it closes. If it does not close back when you release, or if it is allmost in this condition, then you turned it too much, go back
Pj
Re: Inquiry on Cooper Lighting, Model NH1204M « Reply #62 on: October 11, 2016, 05:34:58 PM » Author: Pj
What's a bit puzzling, is the old one didn't take much pressure
to move the relay to have it close.
The newer one is under more tension to close it.
I'll have to try it one day.
Thanks.
 - Pj
Re: Inquiry on Cooper Lighting, Model NH1204M « Reply #63 on: October 15, 2016, 06:03:43 PM » Author: wattMaster
You can also try those electronic photocells with a silicon sensor, I think they are better made and have a longer life.
But they might be harder to find, and more expensive.
« Last Edit: October 15, 2016, 06:05:47 PM by wattMaster » Logged
Pj
Re: Inquiry on Cooper Lighting, Model NH1204M « Reply #64 on: October 15, 2016, 06:16:54 PM » Author: Pj
Thanks, WattMaster.
The landlord 'paid' for the new controller and MV Lamp.
They've been up and running for a bit now.
I'll try the screw adjustment at some point.
