Author Topic: Streetlight clobbered by football  (Read 6912 times)
Streetlight clobbered by football « on: September 08, 2015, 08:51:16 AM » Author: Lumex120
https://www.youtube.com/watch?v=gsgtJXwJQV4
Hopefully it was HPS, and not MV or MH. This would have been hilarious if it had been a Durastar or LED fixture. ;D
They should have at least put a matress under it to catch it... ::)
« Last Edit: September 08, 2015, 03:51:01 PM by Zarlog » Logged
Unofficial LG Discord
Re: Streetlight clobbered by football « Reply #1 on: September 08, 2015, 11:27:21 AM » Author: dor123
Rusty arm of the streetlight, causing it to be weak?
Re: Streetlight clobbered by football « Reply #2 on: September 08, 2015, 12:31:39 PM » Author: Solanaceae
It looks like a Cooper OVX or OVZ, probably metal halide or HPS, so it's ok. I think Doron is correct, those weld joints get bad after a while.
Re: Streetlight clobbered by football « Reply #3 on: September 08, 2015, 01:14:01 PM » Author: Lumex120
I thought the weld was bad too. Or, they just used the cheapest pole they could find... ::)
Re: Streetlight clobbered by football « Reply #4 on: September 08, 2015, 03:52:51 PM » Author: Lumex120
Do you think the glass breaking sound was added? it just sounds too artificial to be real. ???
Also looks like the football took out the photocell.  :o
« Last Edit: September 08, 2015, 03:57:46 PM by Zarlog » Logged
Re: Streetlight clobbered by football « Reply #5 on: September 08, 2015, 03:56:39 PM » Author: Solanaceae
Those streetlights, especially cobraheads are heavy, maybe 45-55 pounds each, and not including the dead weight of the pole and wiring. The hex bar deadlift bar has a cracked weld from three years of lifting and dropping it (I did 135, not bad for a 5'2 stub, eh? :P).
Re: Streetlight clobbered by football « Reply #6 on: September 08, 2015, 03:59:56 PM » Author: Lumex120
I know. When I had my 70w PSMH ballast in my m250r2, it was very lightweight and I could easily carry it anywhere. Now with a 250w PSMH ballast, it has to at least weight 20 pounds. :o
Re: Streetlight clobbered by football « Reply #7 on: September 08, 2015, 11:17:13 PM » Author: Solanaceae
That looks like a Crouse Hinds OVC. Probably :hps:.
